I dont have any voltage in gpu core DA0ZRTMB6D0 REV D
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    The problem of the laptop was no display when plug to PSU it tasking 100 milliamps when powering on.
    When I check the voltages on the vcore section it doesn't have any voltages 0v
    The gpu chip is not getting hot fan is not spinning only blue light
    I've done flashing bios
    Those anyone has an idea or hint please help me
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: I dont have any voltage in gpu core DA0ZRTMB6D0 REV D
    check +5v VS and +3V VS lines. It seems on switching you are not getting VS Voltage. Which kbc it uses?? Programmable??
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      check +5v vs and +3v vs lines. It seems on switching you are not getting vs voltage. Which kbc it uses?? Programmable??
      +5v is present
      +3v is present
      kb ite it8987e
      • Techtiger
        • Oct 2014
        • 1602
        • france
        after testing VS line test PQ52 +1.05V GFX
        PL10 1.5VGFX page 41
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          Originally posted by techtiger
          after testing vs line test pq52 +1.05v gfx
          pl10 1.5vgfx page 41
          pq52 is present
          pl10 has 1.6v
          • Techtiger
            • Oct 2014
            • 1602
            • france
            PQ14 +3V GFX present?
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              pq14 +3v gfx present?
              yes pin 3 of pq14 has 3v pin 1 has no voltage and pin
              • Techtiger
                • Oct 2014
                • 1602
                • france
                This is missing 3VS PQ14 Gate Voltage is missing 15V ?
                Test PR179 both sides & PQ44 all pins you can put a jumper but !!
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  Yes when I test the PR179 it has 13v only from its source the PR45 has 9v in output drom vin
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    PR45 VIN should be 19V PR46 divides voltage 9V to PQ44 that way PQ44 OFF MODE
                    PR179 input even with 13V to pin 2 of PQ14 it should conduct the gate to by pass +3VPCU to +3V GFX test you PQ14 for short or change it
                    • dj_ricoh
                      • 2073
                      • uk
                      Resistence check coil and both pq46 and 47 every pin
                      • piernov
                        • Jan 2016
                        • 4437
                        • France
                        CPU VCore present? PLTRST# present? Is it booting or not?
                        Usually GPU VCore won't show up if it's not POSTing.
                        Make sure you use good compatible RAM (*PC3L*).
                        Could try another known good BIOS.
                        • on/off
                          • Oct 2016
                          • 333
                          • Indonesia
                          Agree...
                          Look like for POSTing purpose only Intel HD graphics is ON (CMIIW)
                          Agree once more....
                          Also DGPU_PWR_EN come from PCH (SoC)
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            cpu vcore is present. i dont know how to test PLTRST# ?
                            Ive done flashing bios
                            when you plug the psu unit its taking 4 milli amps acouple of seconds
                            • kalilinux25
                              • Mar 2018
                              • 2089
                              • ZAMBOANGA SIBUGAY
                              coil resstance is 1ohms pin 1 to 5 12 ohms pq47 pin 1 to 5 has 30 kilo ohms
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                page 18
                                3V MAIN POWER
                                NO VOLTAGE ON ALL PIN OF Q30
                                +3V_GFX IS NOT PRESENT ON R371
                                +3V_GFX IS NOT PRESENT ON R369
                                Q24 NO VOLTAGE PRESENT ON ALL PINS
                                Q32 PIN HAS +3V_GFX IS PRESENT
                                • Techtiger
                                  • Oct 2014
                                  • 1602
                                  • france
                                  PLTRST# U27 PIN 22 test, Voltage in PQ13 pin 2
                                  • kalilinux25
                                    • Mar 2018
                                    • 2089
                                    • ZAMBOANGA SIBUGAY
                                    pin in pq13 has no voltage and pin 1 pin 3 has 13v
                                    • Techtiger
                                      • Oct 2014
                                      • 1602
                                      • france
                                      can you check PQ52 pin 4 voltage , test PR65 PR179 with Multimeter value ?
                                      test PQ14 pin1 Multimeter Diode mode for value ?
                                      DDR slot pin 30 voltage ?
                                      • lapfix
                                        • Mar 2020
                                        • 2756
                                        • my workshop
                                        PQ13 pin3 must find 9v ,that's the result of voltage divider between PR45/PR46 ..you find this 9 volt at your post n9 , so why you find 13V now!
                                        BTW did you fix it !
