19v power not passing through
  • zhang
    • Jun 2017
    • 50
    • Indonesia
    Hi Folks,
    Recently I encounter motherboard with board code x451ca rev 2.1
    charging ic is bq24725
    which comes with 19v power voltage can not pass the both adaptor mosfet ( N channel )
    checked for the gate ( should be greater than drain pin ) but it appears to be only 1 volts ( which caused the 19v can not go through and only present 1v on PR8806 )
    checked the acdrv pin from ic PU2800 still about 1v
    for the ic, vcc present 19v, acok present 2.5 ( which should be normal )
    changed few pcs of ic, seems to be the same result
    Regards to all
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: 19v power not passing through
    Check if the DC-in MOSFETs are shorted, common issue.
    • zhang
      • Jun 2017
      • 50
      • Indonesia
      Checked, working normal
      replaced with normal working also in vain
      • zhang
        • Jun 2017
        • 50
        • Indonesia
        Originally posted by zhang
        Hi Folks,
        Regards to all
        seems like I accidentally solved it and yet till now still don't understand what is going on and why it turn on normally
        I give 9v power to the adp gate
        and it works
        just wondering what might be problem
        • z3h1r
          • May 2014
          • 10
          • Turkiye
          There is static electricity. Connect the 19 volt adapter to the device. Short-circuit the device at the DC socket.Asus laptops have such a problem.
          • zhang
            • Jun 2017
            • 50
            • Indonesia
            if talking about static electricity,
            the notebook has been disassembly for about two week with no power ( battery, adaptor, cmos )
            that should be quite a long time for non power state
            • zhang
              • Jun 2017
              • 50
              • Indonesia
              if it is because of static electricity, what should I do next time if I encounter similar ( but not the same ) situation?
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
                03-31-2024, 02:12 PM
                09-06-2024, 05:59 AM
