dell vostro 3559 la-d071p does not turn on
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: dell vostro 3559 la-d071p does not turn on
    Originally posted by poweron
    PL605 (VCC_GT) and PL603 (VCC_CORE) = 0v
    PL601 (VCC_SA) = 1.0v only for 1 sec, pressing power buton is present for 1 sec
    PL301 (+ 1VALWP) = 1.0v only for 1 sec, pressing power buton is present for 1 sec
    PL200 (+ 1.35VP) = 1.35v only for 1 sec, pressing power buton is present for 1 sec
    PL100 (+ 3VALWP) = 3.3v always present
    PL101 (+ 5VALWP) = 5.0v always present
    PL700 (+ 17.4V_BATT) = 17.4v battery charging voltage always present
    Test PL605 (VCC_GT) and PL603 (VCC_CORE) resistance mode not in DIODE
    Try and Remove one Leg of PL605 & PL603 to find out if the MB power up with no image
    • poweron
      • May 2019
      • 371
      • italy
      I removed the two coils but the mobo does not switch on, the voltages are not present, the resistance to ground is 6 ohms
      • poweron
        • May 2019
        • 371
        • italy
        Does it seem to me to be too low or is it acceptable?
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Seems to be ok
          • Techtiger
            • Oct 2014
            • 1602
            • france
            take a look at after Page 177 to get a good understanding and Schematic Page 55 power sequence check that out
            • poweron
              • May 2019
              • 371
              • italy
              #26
              I don't understand it very much I have little experience with datasheets
              • poweron
                • May 2019
                • 371
                • italy
                #27
                how do you read a power sequence? do the circled numbers indicate the sequence progression?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  Hey, you have already started understanding it and you are right in your assumption. Power sequence starts with the lower number and last number is where it should post. Just measure the signal lines and see which signal is missing and then you need to go backwards from that point in sequence as thats where the fault lies. Since your mb doesnt even switches , so its not long list of things to check.
                  • poweron
                    • May 2019
                    • 371
                    • italy
                    #29
                    are there numbers repeating on different signals, does this mean that these signals must be present at the same time?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      btw, did you checked the mosfets connected to vrm section. These are a bit complex fets where a single fet is made to replace 2 fets. I found one of those fets faulty on this very mb almost a week back. Symptoms almost similar-it turns on and turns off within few seconds without any display. So do check that part.
                      • poweron
                        • May 2019
                        • 371
                        • italy
                        #31
                        I will check as you say, but what is the vrm section?
                        • Techtiger
                          • Oct 2014
                          • 1602
                          • france
                          #32
                          That's for the CPU section and check this out for power Sequence
                          https://youtu.be/sMES_OuGO80
                          • poweron
                            • May 2019
                            • 371
                            • italy
                            #33
                            who enables the VCC_CORE and the VCC_GT the signal DRMOS_EN?
                            • poweron
                              • May 2019
                              • 371
                              • italy
                              #34
                              the signal DRMOS_EN not present,I note that this notebook had shut down by itself while it was working
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                #35
                                trace back IMMP VR ON
                                • poweron
                                  • May 2019
                                  • 371
                                  • italy
                                  #36
                                  the IMVP_VR_ON signal is present only for 2 seconds together with the power led lighting up when I connect the power connector, but if I press the power button nothing happens
                                  I have to correct: DRMOS_EN is also present for 2 seconds in the same way as IMVP_VR_ON
                                  • poweron
                                    • May 2019
                                    • 371
                                    • italy
                                    #37
                                    I did some checks following the power sequence (some signals I can't find on the kbc), these are the results on kbc:
                                    PCH_ALW_ON = ok pin 71
                                    SIO-SLP-SUS = ok pin 96
                                    PCH-RSMRST = ok pin 88
                                    SIO-SLP-S4 # = present only for 2 seconds pin67
                                    SIO-SLP-S3 # = present only for 2 seconds pin70
                                    RUNPWROK = present only for 2 seconds pin48
                                    RESET-OUT = present only for 2 seconds pin73
                                    there is certainly something that blocks the micro-ec, what do I still have to check all the tensions enabled by the PCH?
                                    • MANISH SAWDEKAR
                                      • Oct 2023
                                      • 5
                                      • INDIA
                                      #38
                                      This is the board of LA-D071P....when the CMOS cell is removed the board gets turned on and the display also comes on...but when I try to turn it on using the on off button it does not turn on....and I can also short it using the multimeter
                                      • mon2
                                        • Dec 2019
                                        • 14848
                                        What is the voltage on the CMOS cell battery? It should be ~3v. If not, replace it.
                                        • MANISH SAWDEKAR
                                          • Oct 2023
                                          • 5
                                          • INDIA
                                          #40
                                          YES 3.3 VOLTAGE AVAILABLE...
                                            DELL Vostro 3559 Notebook 3000 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3559 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3559 boardview and 3559 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3559 Notebook...
                                            09-06-2024, 06:11 AM
                                            DELL Vostro 3671 Vostro 3600 i5-9400 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3671 boardview and Vostro 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                            09-12-2024, 03:44 PM
                                            DELL Vostro 3471 Vostro 3400 i3-9100 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3471 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3471 boardview and Vostro 3471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                            DELL Vostro 3670 Vostro 3600 i3-8100 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                            DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
