Samsung np300e5a turn on but no image
  • jp_jota
    • Feb 2018
    • 48
    • portugal
    Re: Samsung np300e5a turn on but no image
    i have a short sound in this line, but when turn on i have a 1.064V, and in the coil l3 ddr3 line i only have 1.5V without cpu, with cpu have 0V in this line. thanks for the help
    • Techtiger
      • Oct 2014
      • 1601
      • france
      test U507 TPS5111 pin 1 4 6 10 11 voltage with and with out the CPU
      (the short sound in line, but when turn on i have a 1.064V thats normal )
      • jp_jota
        • Feb 2018
        • 48
        • portugal
        without cpu
        1-3.15V
        4-5.012V
        6-bewteen 270Mv and 280Mv
        10-5.091V
        11- 103Mv
        wtih cpu
        1-3.15V
        4-5.003V
        6-0V
        10-5.091V
        11-103Mv
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          Measure resistance on the hot Coil in the photo with and without CPU.
          As you wrote 00.64 Ohms in the photo, I got confused whether it is 0.64 Ohms or 64 Ohms?
          • jp_jota
            • Feb 2018
            • 48
            • portugal
            hello, without cpu its 34.12 Omhs with cpu is 0.64 Ohms
            • caspian
              • Oct 2015
              • 1589
              • Laptop
              #26
              So it seems the CPU is defective. Try to turn the laptop on using another CPU. The CPU should be compatible to this mainboard. If there is no picture on the screen, turn the laptop off immediately to avoid damage to the new CPU. If you have found such a CPU, measure resistance on that hot coil again using the new CPU.
              • jp_jota
                • Feb 2018
                • 48
                • portugal
                #27
                Using a new CPU i turned te laptop on and it showed no image on the screen. Then i measured the resistance that changed from 0.64 Ohms to 0.13 Ohms.
                • caspian
                  • Oct 2015
                  • 1589
                  • Laptop
                  #28
                  I guess this mainboard does not worth repairing. I had many mainboards like this one. after lots of work and repairing, the problem reappeared. I recommend that you buy a new mainboard without Graphics chip for this laptop.
                    09-07-2024, 05:50 AM
                  • shlomim412
                    samsung ua55es6800 - no image
                    by shlomim412
                    hi
                    having problem with samsung ua55es6800
                    tv had backlight on, sound working - responds to the remote control but no image.
                    check tcon board - had 12v in but no other voltages present.
                    when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                    when leaving only left side connected - again no voltages and no image.
                    put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                    kept trying to block less pins on the left ribbon cable...
                    05-15-2024, 05:00 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
