HP Probook 4510S BACKLIGHT PROBLEM
  • ramzi2019
    • Apr 2019
    • 56
    • tunisia
    I'm a beginner so don't blame me.
    I'm getting data in the screen with no backlight. The screen is OK and I've tested with a second data cable.
    So i'm getting this voltages in the motherboard connector. I need your help!
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: HP Probook 4510S BACKLIGHT PROBLEM
    Measure voltage on all pins of U1.
    • ramzi2019
      • Apr 2019
      • 56
      • tunisia
      Thanks for the help
      • piernov
        • Jan 2016
        • 4435
        • France
        Correct schematics for your board attached.
        Measure voltage on all pins of U5001.
        [MOD EDIT] Link to Schematic -> https://www.badcaps.net/forum/troubl...411s-schematic
        • ramzi2019
          • Apr 2019
          • 56
          • tunisia
          Sorry for the mistake
          • piernov
            • Jan 2016
            • 4435
            • France
            Recheck voltage on LCD connector CN4021 because if you have 3V on pin 4 of U5001, you should have 3V on pin 32 of LCD connector CN4021.
            • ramzi2019
              • Apr 2019
              • 56
              • tunisia
              Sorry for being late.
              But i have found that pin 4 of U5001 is going to pin 36 of CN4021.
              • piernov
                • Jan 2016
                • 4435
                • France
                Hum… on the schematics, pin 36 is connected to +VBATR (also connected to pin 38 and 40). It's the main power rail for backlight.
                Anyway for backlight you need the enable signal (output on pin 4 of U5001), PWM signal (called INV_PWM_3 on pin 40) and backlight power rail (+VBATR on pin 36/38/40).
                • ramzi2019
                  • Apr 2019
                  • 56
                  • tunisia
                  For more clarification, The exact name in the motherboard is foxconn ml1-h94v-0 E253117.
                  And I want to correct you: The backlight power rail (+VBATR) is on pin (34/36/38) and
                  according to this fact, i must have continuity between them and same volt reading. But this is not the case (Photo on post 1 with taken measure).
                  The LCD connector CN4021 seems to be strongly soldered to the motherboard.
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    "foxconn ml1-h94v-0 E253117" is just generic marking of PCB, not the motherboard model number.
                    CN4021 is numbered like this:
                    2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40
                    1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39
                    Pin 1 bottom left with the small notch.
                    • ramzi2019
                      • Apr 2019
                      • 56
                      • tunisia
                      Sorry for the mistake and thanks for your great help.
                      I've to recheck all.
                      • ramzi2019
                        • Apr 2019
                        • 56
                        • tunisia
                        This is the new result.
                        I'm suspecting that the 1.42v of pin 40 may be the problem?
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Pin 40 is a PWM signal, voltage doesn't really tell what it looks like but it means the signal is present. For testing you can short it to 3.3V, it will force full brightness.
                          Other voltages are ok. If you don't get backlight even when shorting PWM to 3.3V, it's an issue with the cable or the panel.
                          • ramzi2019
                            • Apr 2019
                            • 56
                            • tunisia
                            I have found that pin 40 is shorted to ground (i used continuity test). Is it normal?
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3588
                              • slovakia
                              how u could have 1,4V on pin shorted to ground?
                              u have boardview and schematic and u cannot do one good measurement?
                              how u could think u can do a repair?
                              • ramzi2019
                                • Apr 2019
                                • 56
                                • tunisia
                                Thank you for your advice.
                                I give up.
                                  • 20795
                                  Can you find C1276 on the board
                                  • ramzi2019
                                    • Apr 2019
                                    • 56
                                    • tunisia
                                    Thanks for all the good people in this board.
                                    finally, i made it.
                                    In order to avoid any trouble, i isolated the pin 40 from the board (Is no longer soldered) and bridged 3v to it.
                                    So the backlight is working again.
                                    This is old and strange but the result is good.
                                    I attached a compressed file with some photos as a proof.
                                    • trepachka
                                      HP Probook 450 G8 Boardview+Schematics - screen backlight issue
                                      by trepachka
                                      I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
                                      Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
                                      Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
                                      03-16-2024, 12:32 AM
                                    • Dobrowol
                                      Asus GA402RK keyboard and kb backlight problem
                                      by Dobrowol
                                      Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                      04-28-2025, 04:30 PM
                                    • ononos
                                      LG M2362DP Backlight problem
                                      by ononos
                                      hello everyone!
                                      As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
                                      I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
                                      So i decided to try to...
                                      03-12-2023, 05:05 AM
                                    • fanaticgames
                                      Samsung UE32D4010 Backlight problem, led ok
                                      by fanaticgames
                                      hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                      02-22-2023, 09:46 AM
                                      HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-07-2024, 07:12 AM
