HP omen 15 does not power on DAG3AAMBAE0
  • vanrepair
    • Oct 2018
    • 10
    • canada
    Hi people, I was handed an hp omen 15-ce020ca to have a look at. It does not power on at all. The light by the charge port blinks an amber colour once when its plugged then that's it, no other signs if life. If press the power button as soon as I plug in the charger it blinks white first then amber then nothing. If I remove the battery then plug it in, it blinks white once then nothing. If this laptop was working normally would it power on without an installed battery? I've tested the charger and it is giving me the right 19.5 volts. It is an HP brand 150W charger and I would not have reason to suspect it is bad. I could not find any information about what 1 short amber blink should mean. Has anyone seen this before? Any insights? Thanks in advance
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: HP omen 15 does not power on
    remove the main battery, CMOS battery, and HDD. then, turn the laptop on using the AC adapter only. I guess there is a short on the mainboard.
    • vanrepair
      • Oct 2018
      • 10
      • canada
      Yeah I've tried removing everything I could and swapped in some good ram but still the same result. The board looks clean as a whistle but it looks like I'll have to probe it and see if I can find anything
      • ronelex
        • Oct 2016
        • 195
        • Philippines
        the same issue with mine, Im still looking for the solution, 3vpcu and 5vpcu are present, no power on, amber lit slight but blinking
        • gon_tech
          • Oct 2019
          Hi. Did anybody find the solution to this problem ?. I was handed a HP Omen 15-ce015dx with the same behavior that vanrepair explained.
          Thanks in advance for any light on this
          • gon_tech
            • Oct 2019
            The motherboard is a DAG3AAMBAE0
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Check AD_ID .Original adapter in use??
              • rediii
                h???, spurrrn
                • Mar 2018
                • 504
                • somewhere in europe
                3.3 v bios present?
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  have you tried to reprogram the bios with the correct version ? I solve a similar issue on the same mobo.
                  For the smart adapter AD_ID check the presence of 19v on the center pin (be careful not to cause shorts) .
                  • dssence
                    • Mar 2007
                    • 31
                    Hello muy friend, my story is similar I just got from a friend a DAG3AAMBAF0 rev F. This was the initial behaviour.
                    - Power jack on dc connected Solid light, when press power button turns off and then solid again.
                    Measured all coils , I had 5v always, near it there's 3v always but wasn't there. I removed current sense resistor and measured resistance and had a short. Injected voltage and Charger IC heated up with thermal camera. Removed it replaced and same behaviour again. All coils resistance showing no shorts.
                    So I said it might be a problem with the KBC as the KBC manages the enable signals going to the DC converters. I decided to remove ITE 8987E to reprogram with rt809h removed it soldered on the socket for my programmer but it wasn't detected ( could the IC be failty? probably). Soldered it back again to program it online, I soldered all cables for all KBC lines KSOx to KIx , and when I connected it again no response wasn't detected. Now this is what happened while I was taking some measurements, by bad luck I had the programmer socket moving around the pcb it slided on top of the kbc connector and the KBC went dead.
                    So now i'm left with the machine with no solid led light on the dc jack. And besides that, I don't have 19V past the 1st mosfet. I don't understand how does the IDEA_G signal work? to enable 1st mosfet gate. and i also can't find the dual pnp array. on the board.
                    • mon2
                      • Dec 2019
                      • 14760
                      Current sense resistors are always very low in resistance value. Typically < 1 ohms so they will appear as a "short". If the resistance was too high, then the part will heat up dramatically while passing the current from one side to the other. Rarely are current sense resistors the fault.
                      3v always
                      Work on fixing this fault. Locate and identify the part that creates this rail. Share a clear picture of nearby ICs. As the net name implies, "3v always" must always be present for the logic board to operate normally.
                      Can you link or post the logic board schematic? Will check my database in the meantime.
                      • Francisco.s
                        • 686
                        • Spain
                        IDEA_G is the bias circuit to make PQ1002 to saturate and pass the +VA voltage to +VAD point.
                        In order to get this, PR1005 puts the gate of PQ1002 to ground through it. This is only possible if PQ1004 is not damaged or bad biased.
                        You can remove PQ1004 to ensure that it doesn't interfere. (only for testing)
                        PQ1004 introduces some delay to limit the inrush current.
                        • jithinkn
                          • Jul 2018
                          • 40
                          • UAE
                          Re: HP omen 15 does not power on DAG3AAMBAE0
                          No power ,5v always 3.3v not precent
                          • jeangonbay
                            • Jun 2021
                            • 22
                            • La RĂ©union
                            what is the reference of this chip ?
                              HP OMEN OMEN by Desktop PC - 870-180na OMEN 870 i5-6400 Specification for Upgrade or Repair
                              This specification for the HP OMEN OMEN by Desktop PC - 870-180na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-180na boardview and OMEN OMEN by Desktop PC - 870-180na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              09-12-2024, 03:44 PM
                              HP OMEN OMEN X by 900-189na OMEN i7-7700K Specification for Upgrade or Repair
                              This specification for the HP OMEN OMEN X by 900-189na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN X by 900-189na boardview and OMEN OMEN X by 900-189na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) OMEN i7-6700 Specification for Upgrade or Repair
                              This specification for the HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                              HP OMEN X OMEN X by 900-187na OMEN X i7-7700K Specification for Upgrade or Repair
                              This specification for the HP OMEN X OMEN X by 900-187na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by 900-187na boardview and OMEN X OMEN X by 900-187na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                              This specification for the HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
