About N-Mosfet P0903EBA have a other same pin to pin part?
  • Jmmy
    • Jan 2016
    • 18
    • The Netherlands
    I have a question with part N-Mosfet P0903EBA, who can help me? I have search*some function and pin to pin of other part.
  • Jmmy
    • Jan 2016
    • 18
    • The Netherlands
    Re: About N-Mosfet P0903EBA have a other same pin to pin part?
    A5-a5(vgn,gnc,gnd) / a5(agm)
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      u can replace with any N-channel mosfet with same or higher current and comparable size
      standard single mosfets have same pinout
      • edugimeno
        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
        by edugimeno
        Hi There!
        I'm trying to help my friend who owns a restaurant be just bought.
        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
        It's stuck using, I guess, the 2 sided tape that comes with the strip
        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
        09-05-2024, 09:34 AM
      • G-Sting
        iPad Pro A1876 SHORT Part Identify Help Needed
        by G-Sting
        So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
        So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
        i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
        SO My main concern is what part should i order what should i search the name for ?
        on Ipad...
        05-15-2025, 09:30 AM
      • Yanleb
        Panasonic part number in service manuals
        by Yanleb
        In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
        This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
        For an example, look at the attached PDF.
        Do you have a way to cross reference the Panasonic part number with the actual part number?
        Thanks....
        07-03-2023, 08:16 PM
      • FreakyMex
        Trouble to identify part (Lunii screen) for replacement
        by FreakyMex
        Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
        I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
        02-17-2025, 01:16 AM
      • esinior
        Smd code to part number
        by esinior
        Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
        I've attached pics of this part
        Thanks...
        08-20-2024, 02:50 AM
