Apple 820-2179-C - have G3HOT, 3V, 5V, but no fanspin, no charger light
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3578
    • slovakia
    have this Apple 820-2179-C board that have G3HOT, 3V, 5V, but no fanspin, no charger light
    have SMC_RESET_L, SMC_ADAPTER_PRESENT
    try to short to ground PM_PWRBTN_L, but nothing
    why no fanspin and no charger light?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3578
    • slovakia
    Re: Apple 820-2179-C - have G3HOT, 3V, 5V, but no fanspin, no charger light
    hahahha
    it is so funny that i mistakenly found something. i want to measure resitance on Q4830 between pins 2 and 3/SMC_ONOFF_H - GND/ to measure if it is switched, but i mistakenly measure pins on Q6940/PP18V5_G3H - PP18V5_DCIN_ONEWIRE/ and the board come back to life with fanspin and green light on charger. and so i measure that im missing PP18V5_DCIN_ONEWIRE
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3578
      • slovakia
      here are my measurements.
      Q6940 is P channel so i think 12.55V is low enough to switch it on. but it wont switch and when i jump jump it with tweezers, i have fanspin and green light on charger so i think it is bad.
      two boards, same symptoms
      do u agree?
      • piernov
        • Jan 2016
        • 4435
        • France
        Hum yeah that's a bit strange that the MOSFET doesn't switch on. But if you don't have a short to ground on its drain and jumping it works then yes, it may be bad.
        -6V between gate and source is usually a good enough voltage to make it switch.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3578
          • slovakia
          i jump it and it look like is good. board respond to power button and charging, but still no video or chime. the other board looks fully working. custommer have only one macbook, so the other board i think will be not repaired.
          Do u think it will be some problems if i leave it just jumped?
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3578
            • slovakia
            damn i forgot that the othe board wil not be repaired, so i take component from it
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
            • motormayhem
              Lenovo T460 Only Charges on One Charger
              by motormayhem
              Laptop Question
              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
              05-12-2023, 01:46 PM
              Apple iPhone Charger Schematic
              Apple iPhone Charger Schematic...
              10-02-2024, 01:30 PM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
            • Johndill
              Dell Inspiron 7567 LA-D993P odd charger issue
              by Johndill
              Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
              There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
              I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
              Here are the tested scenarios:
              1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
              2. With the laptop off, plug in charger (LED says on) & the front charging...
              11-16-2022, 10:55 PM
