asus transformer with ripped microUSB connector charging only 0.41A
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    Is there on micro usb connector pin some current sensing?
    have two of this asus transformet with ripped microusb connector so i can only connect plus and minus pins. other pins have missinch traces. when i connect charger it show charging, but current is only 0.41A. is on some pin some sensing that prevent to charging with bigger current?
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    Re: asus transformer with ripped microUSB connector charging only 0.41A
    dead battery?
      • 21922
      What model number is it .
      • piernov
        • Jan 2016
        • 4439
        • France
        You need the USB data lines if you want to go above 500mA
          • 21922
          For the T100HA https://www.asus.com/support/FAQ/1015067/
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            can u please tell me how it works? it uses data lines for charging or it uses it for triggering more current?
            • gabiz_ro
              • Mar 2011
              • 171
              • Romania
              On USB charging standard you need to short data + with data - to enable charging. (on device side)
              In most cases limited to 1000mA but I see in more cases even more but depends on charger and cable quality.
              So if you are unable to wire data traces to usb socket,and only VBus and GND are connected,you must find where on board you can bridge together D+ and D- so when charger connected will charge.But no more USB conectivity,only charge.
              You may post good picture of area with usb socket (both sides of board) and maybe someone can figure out where data connetion are and you can wire them to usb socket.
              In most cases data lines are through some double emi filter and have some esd protection,easy to identify.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                bridge is not a problem, but did i loose usb connection on other usb ports?
                • gabiz_ro
                  • Mar 2011
                  • 171
                  • Romania
                  No.
                  Only on bridged port.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    many thx mate. it worked like a charm.
                    i learn something important today
                    • gabiz_ro
                      • Mar 2011
                      • 171
                      • Romania
                      With some skills and good soldering iron you can wire usb socket as is designed so you have charging and data link on this usb port.
                      I did that on many phones.
                      It’s a nightmare when some phone come in service and usb charging was solved just by Vbus and gnd by others.
                      So,always restore all pins on usb,charging,data lines and id.
                      Encountered few times,repairs done by others services,Vbus and gnd soldered OK but they shorted d+ and d- and also id
                      As result phone or tablet trickle charge battery but when battery enough charged becouse id was shorted too enter to OTG mode result was endless loop .
                      Charging,logo startup,restart.....
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3627
                        • slovakia
                        With some skil and good soldering iron you can wire usb socket as is designed so you have charging and data link on this usb port.
                        it is not needed because there is usb3.0 port and another big usb2.0 port on keyboard. even this repair was not needed but it was wanted
                        • 5mall5nail5
                          Help identifying connector for ASUS 4090 Strix RGB LED connector
                          by 5mall5nail5
                          Hi All -
                          I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                          Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                          05-04-2025, 07:47 AM
                          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 12:00 PM
                          ASUS Transformer T304UA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T304UA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA boardview and T304UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...
                          09-06-2024, 11:50 AM
                          ASUS Transformer T304UA-GN042T Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T304UA-GN042T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-GN042T boardview and T304UA-GN042T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          ASUS Transformer T304UA-XS74T Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T304UA-XS74T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-XS74T boardview and T304UA-XS74T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:06 AM
