eeprom programmer - chip holder
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Hello.
    have this cheap bios programmer, but holder of chip worn off really fast. i cannot find it on aliexpress. know somebody name of this holder so i can be able to order it?
  • shandybass
    • Nov 2018
    • 23
    • United Kingdom
    Re: eeprom programmer - chip holder
    That's a 16 way zif socket, loads on ebay etc;
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      tnx mate. found it
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
        by SMDFlea
        Bad...
        09-02-2021, 04:40 PM
        How to add chip support to NeoProgrammer software for the CH341A Programmer
        by SMDFlea
        Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
        and once you do find them there`s a few crucial steps missing.
        Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
        Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
        After adding the chip save the xml file and copy it to the root directory of the...
        05-26-2024, 07:15 AM
      • Donny2derby
        Recommended chip programmer for eeprom etc.
        by Donny2derby
        I keep seeing people in the Tv forum asking for eeprom programming and a lot of them seem to use a CH341a.
        Is there a reason why this seems to be so popular? Or are there better and preferable alternatives?
        Are there ones which a novice would be better off using?
        Any suggestions welcome.
        03-30-2024, 08:53 AM
      • BMCappelletti
        Asus Chromebox CN62 - wrong chip put on BIOS reader
        by BMCappelletti
        Long story short:
        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
        - gave the computer to his son a couple years later
        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
        (seems like the story was not that short)
        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
        01-08-2025, 07:27 PM
