lenovo yoga 500-141BD power goes off a few sec
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello guys....need your help
    i got lenovo yoga 500
    LT41 MB 14217-1M
    it turn on a few sec then off.
  • YOUN
    • Feb 2015
    • 80
    • Burkina faso
    Re: lenovo yoga 500-141BD power goes off a few sec
    Hi.help me to found bios for lenovo x130 da0fl8mb8c0 rev c
    thank!
      • 21061
      thank!
      This post is about a yoga 500-141BD ,why don`t start a new thread in the "Bios Requests" ,its highlighted in red .
      • johnbad
        • Jul 2013
        • 4
        • Romania
        LT41 MB 14217-1M
        Does it have "Lenovo" splash screen when it's powered on?
        • rickybucalan
          • May 2013
          • 322
          • philippines
          no
          • rickybucalan
            • May 2013
            • 322
            • philippines
            updates ..
            i tried new battery and its work with the battery only..
            but not charing.
            not working with charger.
            checked charger " good"
            checked charging pin "good"
            checked voltage in mobo 20v "good"
            what is wrong guys...pls help
            • Techtiger
              • Oct 2014
              • 1602
              • france
              updates ..
              but not charing.
              Upload the Schematic if you can
              What is your Charger IC BQxxx or ?
              • rickybucalan
                • May 2013
                • 322
                • philippines
                cant find schematic..
                charger ic is isl 95520HRZ
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  cannot find the datasheet for this test all pins for VIN with out battrey it's other side of the MOB
                    • 21061
                    The Compal LA-D071P has a ISL95520HRZ (PU703) on page 4 of the schematic ,and on page 42 as ISL95521HRZ (PU703).
                    LT41 MB High res images:
                    https://drive.google.com/open?id=0Bw...ldBMDNiU0FaWXM
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      Thanks SMDFlea
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        ISL95520HRZ test pin 1.2.30.32
                        • rickybucalan
                          • May 2013
                          • 322
                          • philippines
                          pin 1 = 2.9v
                          pin 2 = ov
                          pin 30 =0v
                          pin 32=19v
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            pin 1 = 2.9v
                            pin 2 = ov
                            pin 30 =0v
                            pin 32=19v
                            Now test your 1st 2 Mosfets for voltage in all pins and for short in Diode mode multimeter without power or Battery
                            • bogdan039
                              • Dec 2018
                              • 60
                              • Romania
                              The same issue , the same model.
                              In pin 18 at ISL95520HRZ is one resistor 10 ohm.
                              In found this resistor with big resistance,about 80k ohm.
                              On pin 18 shoul be about 19v but was just 16v.
                              PR743=10 ohm on Compal LA-D071P.
                              • siroos_tz
                                • Feb 2014
                                • 120
                                • the UK
                                • palady
                                  • Jan 2014
                                  • 20
                                  • si
                                  Yap you are good. I have board lt41-14271 YOGA with the same chip PIN 18, VERY LOW VOLTAGE (must be DCin adapter or battery). I found bad resistor (PR4437) 2.2 ohm.
                                  • mon2
                                    • Dec 2019
                                    • 14271
                                    The low resistance may be normal and is for a current sense resistor. Can you link a schematic if you have one?
                                    Which pin has this resistor?
                                    Yes, the dcin should not be low. Remove all power and review to locate mosfets that will be nearby. The mosfets are like solid state relays that pass the voltage from your dcin adapter to this ic but only if the gate pin is the correct voltage.
                                    Share full details of the mosfet markings so we can check if the mosfets are N-channel or P-channel.
                                    Which logic board are you repairing? Post all details.
                                    • gokhankelebek
                                      • Dec 2015
                                      • 10
                                      • türkiye
                                      ISL95520HRZ There is a 3.2k resistor in front of the 18th leg output, remove it, insert a 10 or 20 ohm resistor, the battery will start charging
                                        Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-07-2024, 05:00 AM
                                        Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                        Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                        This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                        Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                        This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
