Display problem Asus Rog G750JX G750JZ
  • thinkfast76
    • Mar 2017
    • 46
    • italia
    I have a problem with these two notebooks, both of which work on external monitors but not on their displays.
    All this after trying to reverse the monitors.
    The G750JX has a FHD 120hz display while the G750JZ is 60hz, I think this has caused the damage, I attach the photo of the power supply circuit of the G750JX display with a burned mosfet.
    I would need the schematic or good advice to solve the problem. Thanks
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Display problem Asus Rog G750JX G750JZ
    its Q45502 N-MOSFET PMN45EN TSOP-6
    Pin 1 +LCD POWR S
    Pin 2 +LCD POWR S
    Pin 3 L VDDEN RR
    Pin 4 +LCD POWR S
    Pin 5 +LCD POWR S
    Pin 6 +LCD POWR S
    hope it will be help full
    • thinkfast76
      • Mar 2017
      • 46
      • italia
      Pin 1 +LCD POWR S
      Pin 2 +LCD POWR S
      Pin 3 L VDDEN RR
      Pin 4 +LCD POWR S
      Pin 5 +LCD POWR S
      Pin 6 +LCD POWR S
      THX a lot , i try with this
      • thinkfast76
        • Mar 2017
        • 46
        • italia
        So this make me mad .........
        I check G750JX J4701 connector and i try this I found these tensions:
        pin 1-2-3 19v
        pin 4 0
        from 9 to 18 5v
        Pin 22 0,24v
        from 23 to 37 0v
        pin 38 3v
        pin 40 3.20v
        I would like to change all the connected components that give 0, or if someone can tell me the specific that could be damaged, I would be really grateful
        • Techtiger
          • Oct 2014
          • 1602
          • france
          pin 23 to 38 are signels you have to use DSO
          pin 22 Ov or 24V ? it should be 3.3V
          Pin 9 to 18 if it’s LCD VDD it must be 3.3V
          • thinkfast76
            • Mar 2017
            • 46
            • italia
            Pin 9 to 18 if it's LCD VDD it must be 3.3V
            PIN 22 is 0V
            ANd sorry , what's DSO?
            BTW , why i have this wrong voltage on 9 to 24 and 22?
            THx a lot mate
            • Techtiger
              • Oct 2014
              • 1602
              • france
              DSO Oscilloscope
              for the BL EN 3.3V test R4509 both side C4506 D4502 D4501 R4509 R4513 all Voltage's
              in you Mob do you have J4501 ?
              for LCD POWR 3.3V Q4503 all pin
              • thinkfast76
                • Mar 2017
                • 46
                • italia
                DSO Oscilloscope
                So i test:
                R4509 1 2,30v 2 0,24v
                c4506 1 0,25v 2 0v
                d4501 1 3,25v 2 3,25v 3 0,25v
                d4502 1 0,25v 2 3,25v 3 0,25v
                r4513 1 0,23v 2 2,3v
                q4503 5,09 drain 0 gate 0 source
                Hope that y can help me
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  now test Q4501 pin 2.3.5.6
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    and test L4501 both sides
                    • thinkfast76
                      • Mar 2017
                      • 46
                      • italia
                      Thx my friend
                      IK check this on q4501:
                      2 3,2v
                      3 8,5v
                      5 0v
                      6 0v
                      • thinkfast76
                        • Mar 2017
                        • 46
                        • italia
                        Ok i wil check this too
                        • thinkfast76
                          • Mar 2017
                          • 46
                          • italia
                          L4501
                          1 5v
                          2 5v
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            Originally posted by thinkfast76
                            So i test:
                            c4506 1 0,25v 2 0v
                            R4509 resistor is suspected in put 5V out put 2.30V this voltage goes through L4507 to pin 22 of J4701 (BL EN) 5V
                            this 4 SMD compontents are connected with R4509, first check C4506 cap short then test D4502 D4501 R413 with the help of the multimeter with out power
                            if you can remove D4501 & R413 and power up and test weather the R4509 out putting 5V
                            • thinkfast76
                              • Mar 2017
                              • 46
                              • italia
                              seen today r4509.
                              On my card is not present, I only saw the tensions on the pitches, but the component does not exist.
                              How is it possible?
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                what are the component not exist R4509 ? or the rest did you replace the Fet that was burned
                                • thinkfast76
                                  • Mar 2017
                                  • 46
                                  • italia
                                  r4509 dont exist, i check just the pad, l dont replace it
                                  • Kingblue
                                    Asus G750JX/JW problem with kb lights, USB ports and touchpad / Bios Problem?
                                    by Kingblue
                                    Hi im new here and i hope you guys can help me maybe.
                                    I buyed an old Asus G750JX and the seller told me it was running perfect after shutdown it never bootet again.
                                    So i buyed this G750JX and open it. after cleaning and checking all inside i startet it.
                                    It was booting perfectly. i played a clean win 8.1 on it.
                                    After installing all and update all to the last drivers it was running very good.
                                    Thinks that dont worked
                                    Keyboard back lights and cant start with fn+f4 all other fn+f working
                                    3 of the 4 USB 3 Ports are not working.
                                    the...
                                    03-20-2024, 05:31 AM
                                  • lazaro.089
                                    Asus Zephyrus M16 / GU603ZW problem
                                    by lazaro.089
                                    Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                    CPU: Core i9-12900H
                                    Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                    Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                    The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                    08-26-2025, 06:33 PM
                                  • AtelierRepa
                                    ASUS X712JA problem
                                    by AtelierRepa
                                    I have a problem with the bios, let me explain.
                                    With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                                    I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                                    My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                                    The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                                    06-15-2024, 04:33 AM
                                  • greg1985
                                    Asus dabkxmb18b0 rev.b bios problem
                                    by greg1985
                                    Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
                                    I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
                                    I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
                                    10-20-2025, 11:34 AM
                                  • boticario
                                    problem with asus tuf A17 FA707NUR
                                    by boticario
                                    I’m trying to recover an ASUS TUF Gaming A17 FA707NUR (Ryzen + RTX 4050, 2023 model).
                                    The laptop powers on, fans spin, but the dGPU (NVIDIA) is not properly initialized — sometimes it shows up in Device Manager with Code 43, sometimes black screen.
                                    After several BIOS downgrades/upgrades (versions 300, 301, 303) and EC resets, it thinking looks like the EC firmware (IT5570VG-256) might have a persistent fault or flag stored in flash.
                                    I already extracted the BIOS .CAP files and DXE sections with UEFITool and IFRExtractor, but I couldn’t find...
                                    10-18-2025, 04:37 PM
