toshiba c850 no power
  • hazim
    • Mar 2016
    • 62
    • egypt
    hi i have Toshiba c850 plf/csf 45w uma dsc mb rev 2.1 with AMD chip and pch chip
    problem that 20v on charger resistor is ok
    but ic tps 1225c is very hot - no short in this circuit
    i replace it but still to much hot
    i replace io ene kb 930qf-a1 but ic 1225c still very hot
    on power supply show 0.136 amps
    i need you help thank you
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: toshiba c850 no power
    to get help, first upload the schematics of your laptop. I found the following one, but it does not have kb930:
    https://www.badcaps.net/forum/attach...3&d=1538566332
    • hazim
      • Mar 2016
      • 62
      • egypt
      i'm so sorry this is exact schematic io nuvoton not ene kb i replaced io nuvoton but i'm confused between to motherboad toshiba in my shop
      you'r right my frind this is mb photo
      and ic 1225c circle by yellow
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        In addition, I do not find IC 1225c in the schematics file.
        • Conste
          • Oct 2018
          • 235
          https://cdn.badcaps-static.com/pdfs/...2c6e6f33b6.pdf
          This should be the datasheet of TI 1225C
          • hazim
            • Mar 2016
            • 62
            • egypt
            first i want to thank you
            this mother board have ic 1225c on board and i see another 2 main board like this mb i see 1225c on it
            but in the schematic i see another one
            i search and get this ic datasheet
            http://gulfup.co/50g713uywvpu
            slvu735.pdf - 969 KB
            • hazim
              • Mar 2016
              • 62
              • egypt
              this mother board have ic 1225c on board and i see another 2 main board like this mb i see also 1225c on it i'm sure
              but in the schematic i see another one tps 51123
              this ic on mb is tps 51225c i'm sure
              thank you
              • piernov
                • Jan 2016
                • 4439
                • France
                If the TPS51225C still heats up after having been replaced most likely VREG3 or VREG5 is shorted to ground. Check resistance to ground on both those output.
                Make sure the replacement chip has been soldered on properly.
                • hazim
                  • Mar 2016
                  • 62
                  • egypt
                  vreg 3 pin 3 is ok no short
                  vreg 5 pin 13 is ok no short
                  install new ic tps 51225c but very very hot
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    check all the Mosfets which are connected to TPS51225c for being defective.
                    • hazim
                      • Mar 2016
                      • 62
                      • egypt
                      after i visual inspection this mb i see mini small brunet above mosfet near the coil 5v
                      i replace it soon
                      mb power up but no data
                      i re flash bios - mb is ok
                      thank you so much my friends
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • ju123
                        Toshiba Satellite C50-A won't power down
                        by ju123
                        Hi guys,
                        So, I've been racking my brains on this one.
                        I have a Satellite C50-A which I'm repairing for a friend.
                        I recently replaced the main board due to failure.
                        Following this, absolutely everything works perfectly, except for the fact it won't power down.
                        Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
                        01-07-2022, 04:40 PM
