Toshiba A300 keep restarting ?
  • bianchi77
    • Jun 2016
    • 1121
    Dear Badcaps Member,
    I have an issue with Toshiba A300 keep restarting ,
    If I don't put boot on USB , it's stable,
    but by the time I try to boot with Ubuntu 16 on USB, it's restarting all the time,
    I have put a new heat compound and change NEC tokin capacitor,
    What else missing here ?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Toshiba A300 keep restarting ?
    when does it restart exactly? at what stage of booting or in the OS?
    If it is Ubuntu, read the last message of the screen just before the restart happens.
    • bianchi77
      • Jun 2016
      • 1121
      I'm not sure, I can not see anything on the screen,
      only empty blinking cursor I don't use keyboard at all, only boot from USB ...
      Any clues ? or experience relating with it ?
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        now you should test booting from a different OS on a different USB memory.
        • bianchi77
          • Jun 2016
          • 1121
          That's the message and it's freezed on that point,
          What's wrong with it ?
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            the problem seems to be related to a MMC card. If such a card is connected to the mainboard, remove it. then try again.
            does the laptop boot normally from the hard disk if you do not use a USB memory?
            • piernov
              • Jan 2016
              • 4437
              • France
              I guess it's just randomly crashing and it happened that the SD controller was being initialized this time.
              Maybe the replacement caps for the NEC Tokin aren't good enough.
              • bianchi77
                • Jun 2016
                • 1121
                It can run now, but only one core detected,
                suppose to be 2 cores
                Is it half of the CPU failed ?
                ACPI = off on GRUB, ubuntu 16.04,
                Any clues ?
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3610
                  • slovakia
                  it really looks like bad tokin
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    I fully agree with piernov and ktmcross. I'll suggest to replace those caps again with 4X330uf caps.
                    • bianchi77
                      • Jun 2016
                      • 1121
                      I have replaced it with 4x330uF Tantalum Caps,
                      But only 1 CPU can run, looks like the other half is fail.
                      boot with Ubuntu 16.04 LTS
                      I have activated dual core in BIOS but it can not run ?
                      Any ideas ?
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3610
                        • slovakia
                        did u try another OS?
                        • bianchi77
                          • Jun 2016
                          • 1121
                          Windows 7 can not boot, Ubuntu 12 and 18, same response,
                          Fedora 29, must use noacpi=off on grub, then it can boot....
                          is it possible that half of the CPU fail ?
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            where is it notified in the Bios or in the OS that half of the CPU is not active?
                            it may give a clue to solve it.
                            • bianchi77
                              • Jun 2016
                              • 1121
                              It's in the OS
                              Architecture: x86_64
                              CPU op-mode(s): 32-bit, 64-bit
                              Byte Order: Little Endian
                              CPU(s): 1
                              On-line CPU(s) list: 0
                              Thread(s) per core: 1
                              Core(s) per socket: 1
                              Socket(s): 1
                              NUMA node(s): 1
                              Vendor ID: GenuineIntel
                              CPU family: 6
                              Model: 23
                              Model name: Intel(R) Core(TM)2 Duo CPU T9400 @ 2.53GHz
                              Stepping: 6
                              CPU MHz: 2527.474
                              BogoMIPS: 5054.94
                              Virtualisation: VT-x
                              L1d cache: 32K
                              L1i cache: 32K
                              L2 cache: 6144K
                              NUMA node0 CPU(s): 0
                              Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm sse4_1 lahf_lm tpr_shadow vnmi flexpriority dtherm
                              bianchi@bianchi-Satellite-A300:~$
                              I have changed on the BIOS to dual core, but still 1 core in the OS,
                              What is the issue ?
                              I'm thinking that my CPU is half dead....
                                • 21282
                                The T9400 is 1066 MHz FSB .Does the A300 chipset only support up to 800Mhz fsb .
                                • ala_borbe
                                  aka Donald
                                  • 1625
                                  • Malta
                                  and update bios to latest version
                                  Im Back... sort of...
                                  • piernov
                                    • Jan 2016
                                    • 4437
                                    • France
                                    Depends, there are a lot of A300 models. 965 chipsets won't support this CPU (won't even boot), but 3 and 4 series will.
                                      Toshiba Satellite Pro A300-1MK Specification for Upgrade or Repair
                                      This specification for the Toshiba Satellite Pro A300-1MK can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1MK boardview and A300-1MK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                      09-06-2024, 05:27 AM
                                      Toshiba Satellite A300-1RZ Specification for Upgrade or Repair
                                      This specification for the Toshiba Satellite A300-1RZ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1RZ boardview and A300-1RZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Satellite...
                                      Toshiba Satellite Pro A300-22J Specification for Upgrade or Repair
                                      This specification for the Toshiba Satellite Pro A300-22J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-22J boardview and A300-22J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                      Toshiba Satellite A300 A300-14S Laptop Schematic
                                      Quanta BL5S Santa Rosa - Rev 1A...
                                      11-01-2024, 07:49 AM
