Lenovo 14isk
  • gieroncastiel
    • Jul 2012
    • philippines
    Lenovo 14isk
    Can someone help me out on this. lenovo 14isk no display on LED but with display on external monitor. can someone help me out.
    Thank you in advance.
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Re: Lenovo 14isk
    [QUOTE=gieroncastiel;867566]Can someone help me out on this. lenovo 14isk no display on LED but with display on external monitor. can someone help me out.
    About the problem Nodisplay on Actual Screen LED but on External Monitor Have?
    (Wala Sya Display sa Screen nya. pero sa External monitor meron tama ba) On Filipino Language.
    1. try used Flash light maybe no back light.
    2. try test other screen panel. with same type or pin connector slot same.
    • lorins_core
      BlackSmith
      • Dec 2012
      • 552
      • Philippines
      Re: Lenovo 14isk
      Or check the LVDS Cable Sometimes. the Flex cable have problem on this Model...
      (tignan mo yung LVDS Flex baka masyado stretch na. angat balik. baka makuha at baka may putol din gumagasgas sa Hinge "Bisagra" yung Flex)On Filipino Language.
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
      • g1150
        Lenovo G565 Laptop , LCD not turn on, external terminak ok.
        by g1150
        Lenovo G565 Laptop onboard LCD Display does not turn on.
        Only works with external Monitor.
        I am trying to verify that the LCD signals from the motherboard are ok.
        The LCD was working, but over time happened to not turn on more frequently.
        Now dead.
        Possibly the cable from MB to LCD is broken somewhere.
        I just wonder how it is detected if external or internal monitor shall be activated ?
        I found the following schematic on the net:
        Problem 2:
        The graphics chip ATI Mobility Radeon HD5470 seems defective.
        On Win7...
        05-07-2025, 11:51 AM
      • mferna14
        Lenovo YOGA 910-13IKB cannot use External Display
        by mferna14
        Dear Friends., I am working on a Lenovo YOGA 910-13IKB. It is working fine, no problems at all. Today I was connecting to a External Display through the USB-C HUB, it could not connect. (This Lenovo model has only 2 USB-C Port, no HDMI, so has to be connected through a External USB-C HUB). I have changed the setting to External display but still no luck. Re-loaded Windows 11, assuming that the software might be faulty & still same. I know my USB-C port HUB is 100% good (HDMI, USBs, SD Reader) as I use this on all MacBooks & even my buddy has another HUB, still cannot connect to External...
        08-16-2023, 07:58 PM
      • lawrenceptrini
        Lenovo Ideapad Flex 5 14ITL05 Only working on external display
        by lawrenceptrini
        Hi Guys,
        LENOVO IDEAPAD FLEX 5 - 14ITL05
        BIOS VERSION - FXCN24WW
        EC VERSION - FXEC18WW
        MTM - 82HT0004US
        SERIAL NUMBER - R9130MDP
        CPU - i7-1165G7
        This laptop powers on but shows nothing on the internal display.
        However, if I attach an external display it works fine.
        Observations: When I shut down the laptop from windows,
        the fan remains spinning until I close the lid. If I leave the lid open
        the laptop will restart on it's own although I select shut down from windows.
        Also, when I check the voltage on the...
        10-15-2024, 12:47 PM
      • Acnologia
        Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
        by Acnologia
        Here is a pretty crazy one.
        Step 1.
        Laptop was brought to me as dead not working. Removed everything , cleared everything.
        Step 2.
        Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
        Step 3.
        Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
        Step 4.
        Lets ,dive into the board. I see the edp cable on the...
        05-07-2025, 07:16 AM
