Toshiba L735 Battery problem, 2 led blinking orange
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    Hi guys
    I have a problem with my laptop Toshiba L735. Battery status on windows charging but its capacity is not up & down. 2 led blingking orange.
    I have replaced IC charging, EC, PCH and flash bios but the problem is still the same. Does anyone have experience or can solve the problem? please share
    this is original bios
    Thanks you
  • MJ-meo-dmt
    • May 2016
    • 186
    • South Africa
    Re: Toshiba L735 Battery problem, 2 led blinking orange
    Do you have schematic for this board? otherwise give the code on the MB. There should be a nice identification number somewhere on the board with a rev nr and date....
    Also check the HI/LO mosfets, the coil... uhm You have tried another battery? What voltages do you get on the Phase line.
    Do you have a scope? can you see that the charge/phase circuit actually does something? Like view the gates for the HI/LO mosfets and check just before the coil, you should see pulses.
    The other day I also had something similar to this but not on the same machine. I think it was a dell anyways everything showed fine but it also didnt actually increase the capacity of the battery... It came down to being a faulty resistor on the sense lines/traces.. check that you get continuity from the big sense resistor to the charging chip inputs for CSOP/CSIN (Some call it different names. but its usually the same with the prefix of CSxx)
    EDIT: Okay so I found a L730 Schematic for the Toshiba, just to show you have a meant see the Yellow Markings. In the attached Image
    2nd EDIT: Here see THIS POST for schematics.
    while alive { live(toFullest=true) }
    • cyngo
      • Jun 2015
      • 219
      • Indonesia
      problem has been solved by replacing the new PCH and replacing ic tokin with 3 elco 470uF. Thank you for the help.
        09-06-2024, 05:27 AM
      • Jacksoft
        HP ProBook 440 G6 infinite orange blinking
        by Jacksoft
        I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
        The PC worked but it was very slooow to show HP logo in first place.
        A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
        The laptop doesn't power on anymore, and the blinking led happens...
        08-29-2025, 01:24 AM
        09-06-2024, 05:59 AM
