Toshiba Satellite A300 keep rebooting itself ?
  • bianchi77
    • Jun 2016
    • 1121
    Dear Badcaps Members,
    I have Toshiba Satellite A300 keep rebooting itself.
    What 's wrong with it ?
    It's on, I can access BIOS, but by the time inside OS, it's rebooting,
    Could it be a bad caps ?
  • Romy2018
    • Sep 2018
    • 174
    • japan
    Re: Toshiba Satellite A300 keep rebooting itself ?
    if there is nec token caps replaced it
    • bianchi77
      • Jun 2016
      • 1121
      now it's completely off after I plug out and plug back in the battery....
      Any clues ?
      • piernov
        • Jan 2016
        • 4437
        • France
        Yeah this one should have a NEC Tokin under the CPU so it may need to be replaced.
        • bianchi77
          • Jun 2016
          • 1121
          What do you suggest me for replacing it ? thanks
          • Romy2018
            • Sep 2018
            • 174
            • japan
            just replaced with 330uf 4 or 5 tantalum caps
              • 31110
              not tantalum, polymer.
              • piernov
                • Jan 2016
                • 4437
                • France
                Aluminum polymer I guess you mean?
                • bianchi77
                  • Jun 2016
                  • 1121
                  Now it's completely off,
                  And I can not turn it back on....
                  Any clues for hard resetting it ? thanks
                  • MJ-meo-dmt
                    • May 2016
                    • 186
                    • South Africa
                    I'm also with the others. Remove that NECTOKIN shit under the CPU(underside of the MB) And put 4 330uF Aluminum polymer Caps in its place.
                    What it usually looks like SEE HERE
                    What it should look like after the fix, SEE HERE
                    Good luck
                    while alive { live(toFullest=true) }
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Good luck
                      Now it can not start at all, before it can boot, but turn on and off,
                      is it only because capacitors ?
                      • bianchi77
                        • Jun 2016
                        • 1121
                        what's the size of that tantalum 330uF ? what rating ? 3V ?
                        • bianchi77
                          • Jun 2016
                          • 1121
                          that one is good ?
                          https://www.aliexpress.com/item/10PC...b-8e8d22f8bafd
                          • bianchi77
                            • Jun 2016
                            • 1121
                            What's the size of that capacitor ? 7343 ?
                            • MJ-meo-dmt
                              • May 2016
                              • 186
                              • South Africa
                              Look at the links i gave you... they contain visual info of the caps... they are 330uF Capacitance and Voltage should be more than 3V at least. CPU are 0.8 - 1.4V usually depending on make.... any scrap or spare board will have them on. if you dont have 330uf then just do the math and add whatever you have to make that up...
                              Here is another image
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3610
                                • slovakia
                                that is not for NEC TOKIN if he cannot start it
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3610
                                  • slovakia
                                  dont u have ATI northbridge?
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    I'm thinking using this :
                                    https://www.aliexpress.com/item/10PC...30453c00slVmjS
                                    How do you guys reckon ?
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Why buy for these caps. You can easily get them from scrap mb
                                      • bianchi77
                                        • Jun 2016
                                        • 1121
                                        I can not find any on my scrapped mb
                                          Toshiba Satellite A300-1RZ Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite A300-1RZ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1RZ boardview and A300-1RZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Satellite...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro A300-1MK Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A300-1MK can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1MK boardview and A300-1MK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A300-22J Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A300-22J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-22J boardview and A300-22J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
