The graphics driver of the msi ms-16y1 laptop is not installed after the installation of the new windows. The graphic model is gt 520m
ms-16y1
by osrexHello, this is my first post and im just a beginner, so be easy on me guy. thanks
i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
i have no datasheet at all for the LED lights, all i have is its length.
long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,... -
by apologizedGreetings,
I have an Intel Core⢠i3-2350M CPU with only UMA Graphic
When I Install the graphic driver the screen goes black.
I wonder if changing the CPU would solve the problem!
My laptop is Hp Probook 4530s
PS : I flashed the BIOS and updated it to the last version. -
by howardc64Problem
Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
Model & Board Pics
Conflicting Spec
Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
https://www.shopjimmy.com/vizio-gj-2k1... -
by aysatHey guys,
This is weird because i have 2 gigabyte rx 570 gaming and they behave the same. i am connecting it to an lg tv 4K with hdmi. I already disabled onboardgpu in bios. I also observed when i disable gpu under devices , it hangs on black screen. same during installation of drivers. what do you think causing this problem?
Best regads,
Alper -
by charifNeed Audio Driver for Thomson P14C4BK128 (Windows 10/11)
I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
Here are the details:- Model: Thomson P14C4BK128
- Operating System: Windows 10 64-bit
If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
Thanks in advance for your help!-
- Loading...
