Probleme No Power on HP ProBook 650 G1
  • moateez
    • Jun 2014
    • 119
    • algeria
    hello Friend ihave laptop with no power
    i loock for a shematic :6050A2566301-MB-A04 15
    i found transistor ho is burned his number on matherboard is Q4900 end there's a short on his Pins
  • moateez
    • Jun 2014
    • 119
    • algeria
    Re: Probleme No Power on HP ProBook 650 G1
    The trasistor is like this
    writing on him 6c3 like picteur
      • 21869
      It could be a BC817 − 40LT1
      https://cdn.badcaps-static.com/pdfs/...d1aa2a100c.pdf
      • moateez
        • Jun 2014
        • 119
        • algeria
        Thnks sir i will replace him
        But i nedd schematic for the mother board to chek first eny other problème
        • moateez
          • Jun 2014
          • 119
          • algeria
          hello friends please schematic
            • 21869
            Its not available .
            • moateez
              • Jun 2014
              • 119
              • algeria
              sir this transistor BC817 − 40LT1 are the same with my transistor
                • 21869
                I think its the right one.Read the datasheet.Page 1 , 6x = Device Code , x = A, B, or C .The DOT is lead-free
                6C, month 3 ,lead-free .(Note: Microdot may be in either location)
                *Date Code orientation and/or overbar may vary depending upon manufacturing location.
                The orientation means that the date code can be either vertical or horizontal .
                http://www.s-manuals.com/smd/6c
                • moateez
                  • Jun 2014
                  • 119
                  • algeria
                  the bios ic also is burned on
                  • sahamipoor
                    • Nov 2016
                    • 42
                    • india
                    hi..
                    do you find that smd 6c?
                    i need to know it number too..let me know plz
                    • mon2
                      • Dec 2019
                      • 14662
                      Yes, see above starting from post #3.
                      • sahamipoor
                        • Nov 2016
                        • 42
                        • india
                        I searched a lot about this regard..
                        This piece cannot be BC817!!! , because 19 volts or VBAT is connected to its (base )OR PIN 1, and if this transistor is placed and the base is connected to 19, in pin 2 or Emitter of it will definitely damage the i/o chip.​
                        • sahamipoor
                          • Nov 2016
                          • 42
                          • india
                          Click image for larger version  Name:	gg.png Views:	0 Size:	32.3 KB ID:	3202328that is lins in board...pin 3 go to EC pin 97 also to pin 1 w25q128
                          • mon2
                            • Dec 2019
                            • 14662
                            Post more clear pics of this area to review the case again.
                            • sahamipoor
                              • Nov 2016
                              • 42
                              • india
                              i am sure about The communication path of this pieceClick image for larger version
                              • mon2
                                • Dec 2019
                                • 14662
                                Follow this investigation:
                                1) go here:
                                ProBook 650-G1 płyta 6050A2566302-MB-A04- prośba o identyfikację elementów • Forum ELVIKOM
                                2) zoom in on the shared picture and you will see a close by SOT-23 device @ Q3003. Looks to be the same as the above mystery part. Would you agree?
                                3) For this logic board, found a schematic in my database.
                                Q3003 on the above HP board is a 2N7002 mosfet.
                                Click image for larger version  Name:	mystery_part.png Views:	0 Size:	296.9 KB ID:	3202358
                                • sahamipoor
                                  • Nov 2016
                                  • 42
                                  • india
                                  Follow this investigation...
                                  Thank you for your search..
                                  In this case, even if it is a MOSFET, 2n7002 still cannot work like this. Of course, with my experience, because the voltage of 19 volts causes damage.
                                  In the same case, I replaced this part with a transistor and the ec-pch chips became defective!
                                  Because in this case, the gate pin must be connected to 19 without resistance and switch between pins 2 and 3.
                                  Last edited by Vesko356; 01-22-2024, 11:19 AM. Reason: Removed full OP quote with images
                                  • sahamipoor
                                    • Nov 2016
                                    • 42
                                    • india
                                    In this case, I will use your suggestion again and let you know
                                    • sahamipoor
                                      • Nov 2016
                                      • 42
                                      • india
                                      In this motherboard (HP Probook 650 G1 6050A2566301-MB-04):
                                      3.3 /5 v there are ok .. but with so many different bios, the motherboard does not turn on!!! and the RSMRST# pin does not activate!!!
                                      I don't have PM_PWROK and sys_work.
                                      rtc and LID_SW# are good..
                                      this transistor connected to pin 1 25q128 ic and /CS pin... and always is low abow 0.7v!! Should it be like this? This IC is always in writing mode with this voltage
                                      i am confused
                                      • mon2
                                        • Dec 2019
                                        • 14662
                                        For safety, leave the 19v out of the equation. In the end, the mosfet is acting like a switch. Bridge the source & drain pins to force the 'switch to be closed'. Do not solder in a part at this location at all.
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...
                                          09-06-2024, 12:00 PM
                                          HP ProBook 450 G6 + USB-C Essential Power Bank Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + USB-C Essential Power Bank Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + USB-C Essential Power Bank boardview and 450 G6 + USB-C Essential Power Bank schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 11:05 AM
