HP Probook 440 G3 DA0X61MB6G0 REV:G battery or charger problem
  • kronikus
    • Feb 2015
    • 74
    • Croatia
    Hi, I have HP Probook 440 G3, DA0X61MB6G0 REV:G i5-6200U,
    Intel graphics 520, battery HSTNN-Q96C with charging or battery problem. Laptop works fine but doesn't charge battery and show status "0% charging". After some time of constant lighting, charging LED start to flash orange. When battery is removed from laptop on battery terminal I measure about 200mV. But trough drilled holes I was able to measure 14,4V on cells, that slightly dropped on 20W load. So, cells are maybe ok but there is nothing on terminal.
    Does anybody have idea how to solve that?
    TY
  • kronikus
    • Feb 2015
    • 74
    • Croatia
    Re: HP Probook 440 G3 DA0X61MB6G0 REV:G battery or charger problem
    I dissasembled battery pack and found that cells are perfectly healthy but fuse SFH 1412 (12ah4) was blown. Does anyone have schematics or experience with that? I suppose that controller records data about blown fuse and needs reset?
    • piernov
      • Jan 2016
      • 4439
      • France
      If the fuse is blown, BMS entered permanent failure mode (usually due to an unrecoverable issue). You need the key and the software to reset it.
      You should buy a new battery rather than messing with this one. Not really safe to play with lithium battery packs…
      • kronikus
        • Feb 2015
        • 74
        • Croatia
        @piernov Thanks for advice. I was trying to get that battery to life because laptop is throttling on power adapter that I have (45W). I understand that processor needs additional power from battery for speed boost. Currently, maximum is 950MHz under heawy load with Prime95 and all other tests. As beliw limit, things are incredible - CPU sometime works on 80Mhz! So I hope for live battery to see if it is something other damaged.
        • kronikus
          • Feb 2015
          • 74
          • Croatia
          Da0x61mb6g0
          MOD EDIT: Schematic moved to a new thread - https://www.badcaps.net/forum/showthread.php?p=996915
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            did u use original hp charger?
            • pooya_pm
              • Jan 2021
              • 259
              • iraq
              Hi
                NVDC charger configuration...
                11-05-2024, 03:28 PM
                ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                Narrow VDC applications where the system power source is
                either the battery pack or the regulated output of the charger.
                This makes the max voltage to the system equal to the max
                battery voltage instead of the max adapter voltage. Operating
                at lower system voltage can improve...
                11-05-2024, 04:43 PM
              • flat-earther
                how to prevent a connected charger from draining battery when not charging?
                by flat-earther
                I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                So the battery is backfeeding the charger and being drained.
                How can I prevent...
                08-07-2025, 01:04 PM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
                Bauer tool battery pack charging with a HERCULES charger modification
                by sam_sam_sam
                The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                05-06-2023, 12:17 PM
