HP-COMPAQ 14 LA-A995P power issue weird
  • memoslar
    • Apr 2015
    • 122
    • Greece
    I have a motherboard LA-A995P. I' tell you what happened to my customer.
    Battery is in good condition as it seems. After a full charge, laptop when powered up, they had black screen with flashing lights on keyboard.
    After removing the power cord and battery procedure there are these symptoms.
    The laptop powers on only with battery and works good. If we connect the power cord with laptop on, shuts off immediately. BUT the battery charges normally when the laptop is off.
    Crazy.
    As i measure mosfets and power manager around battery and power socket , no problem found in volts...
    HEEEELLPPPPPP
  • qonma
    Kuli Solder
    • Jun 2017
    • 184
    • INDONESIA
    Re: HP-COMPAQ 14 LA-A995P power issue weird
    make sure the mosfet in block charging...its ok cek acin acdet and acok in ic charging
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      DC jack checked?? may be AD_ID getting shorted with +19V
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
      • onix331
        EVGA RTX2070 Weird power stage/I2C issue
        by onix331
        Asking here as a last ditch effort:
        GPU: EVGA RTX2070 Black Edition XC Gaming
        A few weeks ago i noticed a burning electronics smell in my room, after a bit of confusion i realized that the RGB LED light of my GPU was out. Weird.
        I didn't think much of it until i tried to look at the power usage in HWinfo, i then noticed that the entry "GPU Power (Total)" was gone entirely, it would also not boost above 1410Mhz.
        Looking further i noticed that "Performance Limit - Utilization" was always at "Yes". The card did perform mostly...
        05-27-2024, 08:34 AM
      • justice171
        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
        by justice171
        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
        1. Verified that all critical voltages are present:
          • 3.3V and 5V are always present if DC is plugged.
          • 1.8V on the BIOS chip is present.
        2. Checked the power button functionality:
          • When pressed, the voltage drops to 0V, indicating the button is functional.
        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
          • Confirmed connectivity is intact, ruling out issues
        11-26-2024, 12:39 AM
      • claws77
        lenovo flex 5 14itl05 power sequence issue
        by claws77
        hi guys, my motherboard will not start no matter what
        when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
        but rest nothing happens no sign of life.
        this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
        with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
        but now nothing happens no matter how much i wait/ charge/ press and hold power button.
        i have no knowledge of motherboards ....
        10-20-2024, 02:48 PM
