MacBook Pro 820-3332-A (2013 Retina) liquid damage
  • gilbertsmith
    • Aug 2017
    • 6
    Hey guys, I'm trying to repair a 2013 Retina MBP that has some liquid damage.
    This MacBook will turn on and work "normally" but will frequently just go black (but the fans would keep spinning) and will sometimes chime but stay on a black screen. I ran the full diagnostics with ASD 3S155 and everything passed. It will rarely get to the desktop and I can't even get the High Sierra or Sierra installers to finish booting.
    So, I took the board out and checked it over for damage, and found a small amount of corrosion on the back. It looks like something might have splashed in through the fan vent as it's right on the edge of the board. The customer said it stopped working and they left it sit for over a year before bringing it in so it's totally dry.
    I've checked the board view and these capacitors (?) are C7526 and C7536, which are both PPVIN_S5_HS_COMPUTING_ISNS. If I test them I get 12.5v on both of them, not sure what I should get though.
    The rest of the corrosion was mostly on the surface, these were the only things that could have had something under them.
    I feel like I should replace these (or at least pull them up and make sure there's no corrosion underneath them). If I were to replace them, how do I know what to look for? I have several donor boards from older 2008-2011 MacBook Pros I could pull parts off of, but other than trying to find something the same size and shape I can't figure out what these are and what to replace them with! The board view doesn't seem to say what they are. Can anyone point me in the right direction of what to look for as far as pulling parts off another board?
    Thanks!
    Edit: I went ahead and pulled those two caps off the board and they still read 12.5v so I'm thinking they've failed? I guess I just need to know what to put back on there.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: MacBook Pro 820-3332-A (2013 Retina) liquid damage
    U8900
    • gilbertsmith
      • Aug 2017
      • 6
      The board looks mint in that area, am I looking for anything in particular there?
      I should mention that since I took those caps off at C7526/C7536 it doesn't turn on at all anymore so I've clearly made it worse...
      • piernov
        • Jan 2016
        • 4439
        • France
        Rework the solder joints on U8900.
        • gilbertsmith
          • Aug 2017
          • 6
          K, done. Still looks clean there, but no change.
          When I pulled those caps up at C7536/C7526 it stopped booting at all. Before that it would chime and attempt to boot before crashing, so that made it worse.
          How can I find out what kind of capacitors those are so I can make sure I'm putting the right thing back there? One was kind of cooked and there's no markings on them so I just pulled something similar looking off an old board but clearly that didn't work
            • 21922
            You need the boardview and schematic . https://mega.nz/#!24BxxJaB!e8PmteRRz...9ITR7bUeJl0qx0
            https://mega.nz/#!LhJhlY5J!p07_Z2jxY...P1vxMDs3CcooHU
            • gilbertsmith
              • Aug 2017
              • 6
              Oh man I feel dumb. I didn't even know about the PDF. It all makes sense now.. Thanks!
              Ok, so those are 10uf 16v caps. I pulled two 10uf 16v caps off a donor board and put them on.
              The closest match I could find on any of my donor boards was 10% caps where the originals were 20%. That just means the new ones have a tighter tolerance, right? So that shouldn't cause a problem?
              I still get no fans though, where as I did before I took the original caps off.. hm
              • gilbertsmith
                • Aug 2017
                • 6
                So I got it up and running again but it's back to where I started, so those caps either weren't the problem or not all of the problem.
                What it does now is it'll sometimes boot, and after 2-5 minutes it'll just go black. I'll have to hold the power button to fully turn it off before it will wake up again. I don't believe this is just going to sleep.
                Other times it'll chime and stay at a black screen (no backlight at all). I'll have to power cycle it and it'll start up 'normally' again after a try or two.
                Booting to a macOS installer, I've managed to actually get to the gui of the installer only once.. I got most of a Mojave install done before it went off.
                I also got it to run a full ASD test and everything passed
                • Reda123456
                  MacBook Pro (Retina, 15-inch, Late 2013) A1398 need bios
                  by Reda123456
                  MacBook Pro (Retina, 15-inch, Late 2013)A1398
                  I need bios for this macbook
                  06-17-2022, 07:11 AM
                • Gigabit2
                  MacBook Pro Retina Late 2013 shows light, fan spin but no chime
                  by Gigabit2
                  I have a MacBook Pro Late 2013 Retina.
                  When plugged in, it shows an orange light on the charger (without battery connected) and the fans spin. But after about 15 seconds they stop and then never spin up again. No chimes and nothing on the display.
                  There is impact damage to the corners of the casing and one of the USB ports is therefore warped. But the logic board itself looks okay from visual inspection.
                  PPBUS_G3H showing 12.58V at all times.
                  Can anyone help?
                  06-26-2022, 12:05 PM
                • mitchw
                  MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                  by mitchw
                  Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                  It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                  I quickly took it apart and washed the liquid residue off the mainboard.
                  The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                  The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                  Now the laptop...
                  07-16-2025, 07:55 AM
                • mon2
                  A1466 Macbook Air (Liquid damage repair)
                  by mon2
                  Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                  Macbook AIR Model A1466 Diagnostic 09-01-2021
                  Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                  Problems & Resolutions
                  1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                  09-01-2021, 09:31 AM
                • rounin
                  MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
                  by rounin
                  Device Information
                  • Model: MacBook Pro 14” M1 Pro (A2442)
                  • Logic board number: 820-02443-05
                  Original Issue
                  The device suffered liquid damage, causing a short circuit on the logic board.
                  Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
                  Work Performed
                  Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
                  Current Status
                  • When powered on, the screen shows support.apple.com/mac/restore....
                  10-20-2025, 11:15 PM
