Lenovo G40-45 Dead, low voltage on B+ Need help
  • abuhamza
    • Dec 2017
    • 19
    • Indonesia
    I have a Lenovo G40-45 (nm-a281p) motherboad which is dead. I measure there is only 0.9v in B+ while the Vin is 20v
    Please help, where to start troubleshoot the problem, thanks.
  • cellphoneyeta
    ShortedboardGSM
    • Oct 2015
    • 49
    • philippines
    Re: Lenovo G40-45 Dead, low voltage on B+ Need help
    Check charging pin
    • mcoytzhi27
      Mr
      • Nov 2015
      • 43
      • philippines
      Check voltage sensing on PR and mosfet from dc port..
      • abuhamza
        • Dec 2017
        • 19
        • Indonesia
        Originally posted by cellphoneyeta
        Check charging pin
        Pin 1 and 2 = 20v
        Pin 3-5 = 0v
        • abuhamza
          • Dec 2017
          • 19
          • Indonesia
          PQ6 = all pins have 20v
          PQ7 = Pin 1-4 has 20v, pin 5-8 has 0.9v
          Where to measure voltage sensing? sorry, i'm new in this stuff
          • abuhamza
            • Dec 2017
            • 19
            • Indonesia
            And i read from the power sequence, that B+ created from PU401. But there is no PU401 in the schematic that I can find.
            So, what created B+, or which component that created B+
            • abuhamza
              • Dec 2017
              • 19
              • Indonesia
              And weird thing I just noticed, even after i remove the charger, there is still voltage on B+ for a while and it is dropping from 0.9v to 0v very slowly.
              • bumper1
                • Jul 2014
                • 76
                • Poland
                Try replace PQ7, I have got same problem with similar lenovo and this worked in my case.
                "B+" is created from "VIN" through PQ6 and PQ7. PU401 uses it to power itself.
                • Manuel S.
                  Lenovo Yoga 720-15ikb (LA-E552P): DEAD - strange voltage on 5V buck converter
                  by Manuel S.
                  my Lenovo 720 is dead. :-(
                  I guess i have found an issue on the 5V buck converter (**BAC7NH** from Silergy (also called SY8288C 5V)) but i am not completely sure so i want to ask here for some hints.
                  Here is a Schematic of the IC: https://prom.ua/p1498216381-sy8288c-...ac-bacxxx.html
                  When i attach the supply 19V, i only have 1.8V on the OUT (it should be 5V). The IC is getting hot.
                  The EN1 is completely off 0V, EN2 show 1.5V.
                  If i inject 5V on the EN1 the OUT goes up to 2.6V (but never reach 5V).
                  BS seams SHORT to the OUT....
                  03-14-2024, 05:17 PM
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • rddube
                  Lenovo L490 Ram voltage circuit malfunction
                  by rddube
                  Hello friends,
                  Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                  I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                  07-15-2025, 04:41 PM
                • erico
                  Lenovo X1 Carbon BIOS not getting voltage
                  by erico
                  First of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
                  I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
                  So far these are my diagnostics:
                  When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
                  When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
                  If i plug the battery...
                  05-02-2024, 02:40 AM
                • Nagyesz
                  Lenovo ideapad 330ICH - Dead, no volts on coils
                  by Nagyesz
                  Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                  I've never encountered something like this before;
                  No charging light, full dead
                  Lenovo Ideapad 330-17ICH
                  • PL3102: 5 ohms
                  • PL3001: 3.2 ohms
                  • PL3101: 2 ohms
                  • PL5801: 3.5 ohms
                  • PL5501: 270 ohms
                  • PL701: 35 ohms
                  • PL501: 146 ohms
                  • PL503: 390 ohms
                  • PL402: OL (0.27V) +5VALW_P
                  • PL301: OL
                  • PL401: OL (0.03V) +3VALW_P
                  + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                  10-11-2024, 10:12 AM
