asus x200ca need to identify this chip
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help to identify this shorted chip on asus x200ca it has a mark AESD 552 i have attached the image of the board, can anyone help me identify this chip please
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: asus x200ca need to identify this chip
    Monolithic Power Systems NB671LGQ
    • String2016
      • Nov 2015
      • 2238
      • philippines
      thanks piernov for the response i need to find the same chip for this
      • vinceroger69
        • Mar 2012
        • 6714
        https://www.aliexpress.com/item/5pcs...ceBeautifyAB=0
        • String2016
          • Nov 2015
          • 2238
          • philippines
          thanks
          • jepoy12
            • Jun 2020
            • Philippines
            what do u think is the factor if the system completes the boot process if i detached the X200ca IO board from main board and plug the adapter
            • jepoy12
              • Jun 2020
              • Philippines
              now that i shutdown the system using windows process (not through power off button)... i could no longer power on the main board with isolated x200ca IO board if plug the adapter. It seems the hardware demands for physical power on process which i think defective or is it due to faulty bios since before that the system wont POST unless i detached the IO board.
                • 21922
                check all parts on the IO board,resolder all parts.Check the IO cable for damage .
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • BMCappelletti
                  Asus Chromebox CN62 - wrong chip put on BIOS reader
                  by BMCappelletti
                  Long story short:
                  - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                  - gave the computer to his son a couple years later
                  - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                  - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                  (seems like the story was not that short)
                  He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                  01-08-2025, 07:27 PM
                • DynaxSC
                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                  by DynaxSC
                  Hi
                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                  08-04-2025, 12:20 PM
                • Agx03
                  Please help me identify this chip. Asus ROG Ally Z1 Extreme
                  by Agx03
                  This is found between the usb-c port and processor of a Asus ROG Ally Z1 Extreme. I cannot find it anywhere on google. Please help me identify....
                  06-15-2025, 11:27 AM
                • ebugs
                  Asus laptop EC/SIO chip replacement
                  by ebugs
                  Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
                  I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
                  I found the EC chip...
                  09-14-2024, 02:09 AM
