msi cx420 problem installing hd 5470 driver
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this msi cx420 laptop problem installing on this ati radeon hd 5470 already download from official site but cannot i install the driver even i reformatting from windows 7 to 10. does anyone encounter the same issue please share how to solve this issue please
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: msi cx420 problem installing hd 5470 driver
    is there any error message? is there any display problem now?
    • String2016
      • Nov 2015
      • 2238
      • philippines
      no display problem the problem is i cannot install vga driver with this hd 5470.I already tried different driver and also from the manucfacturer site when installing cannot finish it gives error
      • String2016
        • Nov 2015
        • 2238
        • philippines
        I tried different version of AMD CATALYST and also on official sites of msi cx420 drivers still the same error APPLICATION INSTALL: INSTALL PACKAGE FAILURE. anyone encounter this problem on this msi cx420 ATI HD 5740 please help
        • String2016
          • Nov 2015
          • 2238
          • philippines
          anyone please help on this
          • String2016
            • Nov 2015
            • 2238
            • philippines
            this weird problem i update the windows and now it install INTEL HD graphics ,but the resolution is only 1024 x 768.but when i try to install the ati radeon hd 7540 driver still the same issue it gives error
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              how was the Ati graphics behaving previously before this problem get started?
              • String2016
                • Nov 2015
                • 2238
                • philippines
                before came here laptop gives no display turns on so i replaced the nec token caps with tantalum 330uf the it gives display and fully working So i started reformating this laptop form windows 10 and then try windows 7 but still cannot install ati driver
                  • 21102
                  Try this: https://community.amd.com/thread/192261
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    i already tried the same issue cannot install catalyst but intel hd is already installed the only problem is this ati radeon hd 5470 driver. anyone encounter this please share how you solved this issue. I already tried to windows 7 64bit pro but stil the same issue
                    • Bonzas
                      • 471
                      • Indonesia
                      I need some help too, in my case laptop has random restart and sometimes BSOD. after replacing NEC tokin with tantalum no more bsod and random restart. But the problem is radeon graphic not detected event on device manager not showing. Before replacing NEC tokin, on the device manager was 2 grapchic intel HD and AMD Radeon 545V. Then today, i try to replace tantalum with the same NEC tokin, still no radeon graphic show up.
                      • theone111
                        by theone111
                        3. Problem: TV shuts down
                        07-22-2024, 10:36 AM
                      • rodrigo.bernardo
                        Power Suply Led Driver Repair Problem
                        by rodrigo.bernardo
                        I am trying to repair a faulty power suplly for a LED Light.
                        I measure 0 V on the output so LED dont light up, however in the input (out of rectifier), I have 60 V, so the problem must be in the middle.
                        Capacitors seems to be good condition, diode is also good (I tested). No burn signals elsewhere.
                        I attached the pcb board and a shcematic that I draw from observing the PCB. Note that there is an IC with the letters "BVYDLA" (I think its that)... its the only thing I found written on IC.
                        I cant find datasheets of this PCB....
                        01-06-2024, 08:06 AM
                      • adom
                        fingerprint driver problem after bios dump. EliteBook 840 G7
                        by adom
                        Hi, everyone
                        i changed the serial number with the program lbe++ (dump cleaner) after the installation i had to find out that the fingerprint driver is missing. I have tried everything but without success (windows update, hp driver update)
                        How can I fix the problem?
                        HP EliteBook 840 G7...
                        05-24-2022, 10:21 AM
                      • Zeonalbasta
                        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                        by Zeonalbasta
                        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                        09-13-2024, 01:17 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
