Cnx 458 problem on sony vaio
  • Alschepmist
    • Jul 2018
    • 70
    Hi to all (sorry for my bad englisch i speak italian) my problem ist that i have no power and no chrging battery on my sony vaio vpc sa4w9e it see like the cnx 458 dont give out 19 v fuses are okay please help
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: Cnx 458 problem on sony vaio
    Check for short on the board first
    • Alschepmist
      • Jul 2018
      • 70
      You are reading of mainboard or cnx 458 because i have no short on mainboard
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        Fortunately, the CNX458's schematics file is available:
        https://www.badcaps.net/forum/showthread.php?t=53164
        First, measure voltage on pins of W_PQ81 and W_PQ82.
        • Alschepmist
          • Jul 2018
          • 70
          So thats what i v got i hope is understable.
          • caspian
            • Oct 2015
            • 1589
            • Laptop
            these measurements do not give any clue. Instead, voltage on pins of W_PQ81 and W_PQ82 are important.
            • Alschepmist
              • Jul 2018
              • 70
              Direct on the pin are dificult to measaure another way ?
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                instead, measure voltage on both sides of W_PC22 and W_PC19 and W_PC10.
                • Alschepmist
                  • Jul 2018
                  • 70
                  Im in trouble i cannot find the datashet IRFH3707TRPBF i only find IRFH3707PbF but her pin 1.2.3 are G but in the schematich have to be 1 S. 2 G. 3D. Or my fault?
                  • Alschepmist
                    • Jul 2018
                    • 70
                    So i have meauserd w_pq81 and w_pq82 and at w_pq82 at all 6 pin 0 v. at w_pq81 at pin 8 i have got 0.8 volt changing then 0 at pin 7,6,5 0.3 volt
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      W_PQ81 and W_PQ82 have no accessible pins. I think you did not measure them properly.
                      unfortunately, W_PC22 and W_PC19 and W_PC10 are not labeled on the board.
                      • Alschepmist
                        • Jul 2018
                        • 70
                        The pin were accesible for me i used needle but where i can found DC_IN_MOS? Or DC_IN_G1?
                        • caspian
                          • Oct 2015
                          • 1589
                          • Laptop
                          they are connected to W_PC19 which is not labeled. Now, you should measure 19v on at least one pin of W_PQ81. then, make sure you measured the other pins of W_PQ81 and W_PQ82 correctly.
                          • Alschepmist
                            • Jul 2018
                            • 70
                            So definetely DC_IN_MOS are 0 volt i sourced at all the point but still everywere 0
                            • caspian
                              • Oct 2015
                              • 1589
                              • Laptop
                              In addition, measure resistance to GND on all pins of W_PQ81 and W_PQ82 and on the yellow capacitors which are located near W_PQ81 and W_PQ82.
                              you can replace W_PQ81 as the first try to see what will happen.
                              • Alschepmist
                                • Jul 2018
                                • 70
                                I v got no resistance to gnd it s that normal ? I have no contact w_pq81 and gnd
                                • caspian
                                  • Oct 2015
                                  • 1589
                                  • Laptop
                                  yes, it is normal. Now measure resistance between the three pins of W_PQ81. I mean red probe on one pin and black probe on another pin. then, measure resistance between the three pins of W_PQ82.
                                  • Alschepmist
                                    • Jul 2018
                                    • 70
                                    So i think the problem is at w_pu2 BQ24725 beacause on pin 1 to 3 i have 0 volt but i should have 19v can be this the problem ?
                                    • Alschepmist
                                      • Jul 2018
                                      • 70
                                      And at w_pq81 pin number 3 on the schematic i v got 19 volt
                                      • caspian
                                        • Oct 2015
                                        • 1589
                                        • Laptop
                                        it can be w_pu2, but w_pq81 seems a more probable suspect. have you got another mosfet of the same model of w_pq81?
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                          Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
