Hp g6 da0r13mb6e1 quanta r13 rev. E / charging ok/but no power
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    i have this
    HP G6 DA0R13MB6E1 QUANTA R13 REV. E / charging ok, but when i press power key i will see the power light blink and off, i have 3.2v at the start key. any help from please?
    Hispeck
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Hp g6 da0r13mb6e1 quanta r13 rev. E / charging ok/but no power
    how many blinks?
    is there any voltage rails missing after pressing the power button?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      check kbc signals with schematics.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Scoff
        HP Probook 470 G4 - Power and Charging Problem
        by Scoff
        Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
        Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
        07-03-2023, 09:28 AM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • rob_hen
        Dell XPS 13 9370 Laptop, No power, not charging
        by rob_hen
        Hello!
        This is my first post for help, and I am quite newer to board repair, so bear with me.
        I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
        After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
        There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
        My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
        05-01-2025, 09:20 PM
      • Dannyx
        HP Spectre X360 (Quanta Y0D) Not Charging, No Power
        by Dannyx
        Good day folks. It's been a while since I've worked on a laptop, but this one belongs to a very important person - my boss ! - so I'd be great if I could get this one going, but the signs are not good so far. I found the schematic AND boardview right here on our forum - big shout-out to SMDFlea for providing them !
        The laptop doesn't do anything: totally dead. No lights, no power, no fan-spin. I took the cover off and noticed someone had been inside before, as two caps are missing (PC20 and PC29) which are just power-input filter caps, so it SHOULD work without those too.
        01-05-2022, 01:44 PM
