DAX1BDMB6F0 Power Issue
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: DAX1BDMB6F0 Power Issue
    If the battery is known good and charged, it should boot if you don't plug in the AC adapter. If AC adapter is plugged in and there is an issue with the center pin, it may not work.
    Btw I've got a board that won't boot (even on battery only) if I don't pull up AD_ID to B+ with a 2k (IIRC) resistor. Couldn't figure it out, replaced the EC and same. So weird stuff can happen with this center pin identification.
    • Pierre-Yves
      • Jun 2018
      • 28
      Got the new adapter today, plugged it in and the computer started right away. Turned it off and back on right away. The third time, pushed the power button and it blinked once, pushed the power button again, it blinked again and started on the third push of the power button. The fourth time was the same as the third.
      I measured the voltage on the inside of the adapter and it is 19.9V. The pin voltage is 12.5V. I gather there has to be some reason for the lower voltage on the center pin that is logical.
      My battery is fully charged.
      I guess I will have to live with that quirk until it acts up again and does not want to start.
      • Pierre-Yves
        • Jun 2018
        • 28
        Hello - you will have to excuse me but the center pin voltage is not 12.5V but actually 19.9V. I must have had a bad connection when I took the reading the first time.
        Also guess what, I left the computer be with the new charger plugged in for a while and it is now completely unresponsive no matter what I do.
        Back to square one...
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Look for IO thermal protection on page 35 of schematic nad measure voltage on resistors. I faced this issue on a quanta U83 motherboard .
          • BlueMidnight
            • Jan 2015
            • 489
            That sounds like a fun little problem. Though I would consider that more of a phantom adapter detection than a smart pin problem, as the latter seems to be working as intended. There might have been a shorted reverse blocking FET or bad charge IC, etc. making an AC adapter appear to be present.
            The adapter resistors seem to start around 500k for the 45W (my measurement), 390k for the 60W (also my measurement), and 200k-300k for the 90W (from internet sources).
            Using a 2k pull-up should work, but would be constantly forward biasing the protection diode to clamp the ID pin voltage at ~3V. The lower half of the resistor divider (the one on the motherboard) always seems to be 12.5k.
            That's not a bad idea. Measurements can be done at the EC (iTE chip). The relevant pins have "THRM" in their names. H_PROCHOT# is interesting as well.
            And you don't have to abandon taking measurements when the board is temporarily working. Whether it's something like the thermal protection, RSMRST#, or one of the other signals, what you are looking for is something that has a different reading when the board wants to power up compared to when it doesn't. And comparing readings you've taken under various circumstances is certainly one way to spot something useful.
            Originally posted by Pierre-Yves
            [...] the center pin voltage is not 12.5V but actually 19.9V.
            The center pin is connected to 19V via a resistor inside the AC adapter. If you just measure it while it's not connected to anything there will be no voltage drop across the resistor, and you should measure the full adapter voltage.
            However, things change once you plug it into the motherboard. The simplified circuit looks as follows:
            19V --> Resistor (in AC adapter) --> Center pin --> Resistor (on motherboard) --> Ground
            This creates a voltage divider that will place a much smaller voltage than 19V on the center pin. By having different resistors in different wattage AC adapters, the center pin will take on different voltages. The board will read this voltage and know the wattage of the adapter.
            • Pierre-Yves
              • Jun 2018
              • 28
              The adapter is 19.5V, 2.31A, and 45W
              From what you said, if the center pin voltage is altered because of the two resistors as per your diagram, can the resulting voltage be measured, that is of course while the adapter is plugged into the board?
              Also, not quite sure what "using a 2K pull-up" means.
              I will take the motherboard out and check the voltage on the ITE again at the THRM (& Prochot) pins.
              • Pierre-Yves
                • Jun 2018
                • 28
                Hello again,
                I measured the THRM Pins with the motherboard still unresponsive (no charging light or anything...)
                Pin 70: 2.97V
                Pin 71: 3.63V
                Pin 72: 2.93V
                Also measured:
                Bat_I pin 66: 3.61V
                Ad_Type pin 67: 4.00V
                Sys_I pin 68: 1.79V
                Also measured:
                TempMBAT pin 120: 2.67V
                H_PROCHOT#EC pin 124: 0V, that is zero volts
                DGPUPROCHOT# pin 77: 0.22V this pin did not go anywhere so it was difficult to take the measurement...
                • BlueMidnight
                  • Jan 2015
                  • 489
                  First, I have to make a correction... I somehow had the unpopulated diode stuck in my brain. It's actually the zener that clamps the smart pin circuit at 5.6V. Which makes sense, as 6V is a the max voltage for many I/O pins on these boards.
                  And unfortunately, I dug around the H_PROCHOT# circuit and found it's pulled up by the "+1.0V" rail. Since that doesn't turn on until later, the 0V is expected.
                  Yeah, DGPU_PROCHOT# seems to be only for boards with a discrete GPU.
                  It's worth measuring LID_EC# (pin 123) as well. It should be 3V, otherwise it thinks the lid is closed.
                  What do look weird are BAT_I and SYS_I. The charge chip takes the voltage difference across PR177 or PR156 (both 0.01 ohm resistors), multiplies them by some number and places that many volts on the appropriate "_I" pin. This can be used to calculate the current through those resistors. But I keep calculating currents that are really high.
                  For SYS_I, it can be the voltage across PR156 multiplied by 20 or 40 (configured by the firmware). The lowest case would be x40, so 1.79 / 40 = 0.04475V. So there is at least 0.04475V across PR156. That divided by 0.01 ohms = 4.475 amps coming from the AC adapter.
                  For BAT_I, it can be the voltage across PR177 multiplied by 8 or 16 (configured by the firmware). The lowest case would be x16, so 3.61 / 16 = 0.225625V. So there is at least 0.225625V across PR177. That divided by 0.01 ohms = 22.5625 amps coming from the battery.
                  Those readings are absurdly high. Even if they were an order of magnitude lower, they would still be too high for a board that is off. It would be interesting to see if they are different right before you are able to power up successfully vs. when it won't power up.
                  • Pierre-Yves
                    • Jun 2018
                    • 28
                    When I plug in the adapter with the center pin (charging light off) the brown wire coming into the board has 19.9V. The yellow and white wires both have 5V. When I plug in the adapter without the center pin, the brown wire read 0V and both the yellow and white wires have 5V.
                    Before the tests above, I plugged the adapter with the center pin and the charging light came on, so I made some measurements:
                    Bat_I pin 66: 0.81V
                    AD_Type pin 67: 5.57V
                    SYS_I pin 68: 0.84V
                    So both Bat_I and SYS_I are lower whereas AD_Type is higher. The board does not seem to want to power up anymore so I could not take those pin measurements while powered up.
                    Pin 123: 3.22V
                    I then pushed the power button and the charging light went off and the board went unresponsive.
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      Well the BAT_I and SYS_I readings were much better that time at least. The AD_TYPE voltage is getting clamped by the zener diode. It might not be very good for the EC if the zener decided to fail open circuit one day. Along with the slightly high 19.9V, it seems the new adapter has an ID resistor that is too small. But it doesn't really affect the present problem..
                      Just to clarify, were the measurements in this post and your last post done using the same AC adapter?
                      The brown wire is for the center pin. The white and yellow ones are for the 2 LED colors.
                      Another EC signal to check:
                      DSWROK_EC (pin 87)
                      Do keep an eye on that one and also RSMRST# (pin 119) and note if they are different right before a successful power up attempt vs. an unsuccessful one.
                      • piyal
                        • May 2014
                        • 11
                        • Sri Lanka
                        #31
                        thanks
                        • Pierre-Yves
                          • Jun 2018
                          • 28
                          I think it the same power supply but I can't say for sure...
                          For the Pin readings, I plugged the power supply to the card and the charging light went on. Here are the measurements:
                          Pin 87: 0V
                          Pin 119: 0V
                          Then I pressed the power button and the charging light went off. Here are the measurements:
                          Pin 87: 0V
                          Pin 119: 0V
                          I haven't got a successful power up for a while now with the new charger.
                          & by the way, pin 87 does not go anywhere, unless it goes underneath (i.e., to the other side of the board) and I can't see it.
                          Thank you
                          • BlueMidnight
                            • Jan 2015
                            • 489
                            For the center pin voltage to change with the same adapter would be hard to explain. If it's with the same adapter, it's worth examining further. But if the 4V reading was with the original adapter, then that's fine.
                            It's convenient when traces come off of the pins where you can see them. But they can just as easily go the other direction, under the chip. They can even go straight down into a lower layer under the pad the pin is soldered to.
                            Without some new information/behavior, we can't be too specific, but the problem still seems to be centered around the EC. The randomness usually points to a hardware problem, but the firmware can't be ruled out.
                            If I had to choose a course of action I would probably say to resolder the EC. It's pretty low risk if you have soldered dense pins like those before, and if you have a blade tip for your iron (to help prevent solder bridges).
                            Flashing the EC firmware requires having the right programmer since the memory is on the EC itself. And replacing the EC normally requires flashing it as well (unless you can find ones that are preprogrammed for this exact board).
                            • Pierre-Yves
                              • Jun 2018
                              • 28
                              Hi - I have a Weller soldering gun and tried to resolder the EC. I think I messed up as looking under the microscope it doesn't look to good...
                              I went on eBay and bought a new board; that was a dent in the wallet but hey, the computer is nearly $1K so I guess it is worth it.
                              I will let you know how that turned out...
                              Thanks for all your help BlueMidnight, I learned a lot.
                              • BlueMidnight
                                • Jan 2015
                                • 489
                                You're welcome. At least you have the old board for soldering practice...
                                Speaking of which... you should have a nice acute blade-like tip on the iron to solder chips like those (if you don't already). Then you can place it across multiple pins and slide it down parallel to the pins until it slides of the ends. Continue soldering groups of pins like this until all pins have been soldered.
                                The surface tension of the solder makes it pool up against the tip. If the tip is not acute enough (like the common conical or chisel tips), too much solder will be around the tip just as you are pulling it away from the pins. This causes solder bridges across adjacent pins.
                                Also, using flux is a must. The main function of flux is to clean surface corrosion and allow the solder to stick properly. And the more it wants to stick to the pins, the less it will want to hang out in the gap between them.
                                With the right tip and some flux, soldering a chip like that should take seconds. And there shouldn't be any solder bridges you need to clean up afterward. If one wants to form, you just clean the excess solder off your tip and give the pins another pass.
                                • Pierre-Yves
                                  • Jun 2018
                                  • 28
                                  Yes, I will surely need the practice.
                                  One thing I notice though that made it difficult to solder was a layer of wax or epoxy on top of everything and that was probably why I came in with too hot of an iron for too long. I wonder then if there are products to disolve that without damaging the board.
                                  Otherwise I will look into getting more accurate blades. I see they come in many different widths. The EC chip is something like 15.5 mm wide across the pins and it is probably a standard width.
                                  • BlueMidnight
                                    • Jan 2015
                                    • 489
                                    There normally isn't any sort of coating on these other than some fine corrosion on the pins, and flux takes care of that. Anything else can usually be removed with some isopropyl alcohol .
                                    A tip with this kind of shape that is about 5mm wide or so seems to work well (though obviously you want to find tips somewhere that fit your specific soldering iron). There's no need to do all the pins on a big chip in one pass with a super wide tip. Not that that wouldn't work necessarily. But it's a lot of area to keep an eye on at one time. You don't want to accidentally wipe some nearby small components off the board by mistake.
                                    There are also really large tips like this one that are perfect for cleaning the pads under a BGA chip (by sliding it around with some desoldering braid beneath it).
                                    And the best general purpose tips for motherboard work are ones with a shape like this.
                                    Also, soldering irons with the heating element and a temperature sensor built right into the tips work best. Otherwise, you constantly have to adjust the temperature to compensate for the size of the tip and the thermal mass of the area you are working on.
                                    • Pierre-Yves
                                      • Jun 2018
                                      • 28
                                      Hi & thanks for those "tips"...
                                      Ordered a soldering iron with a temperature sensor, a desoldering braid and an ITE chip; hopefully will get these within a week or so.
                                      Can't believe how inexpensive the ITE chip was ($4 to $5). I guess if you know what you are doing, are equiped (& skilled), you can save a lot of money.
                                      • BlueMidnight
                                        • Jan 2015
                                        • 489
                                        Removing a chip like that without a hot air station is a little tricky. Getting enough solder off the pins to be able to lift it cleanly off the board (without bending pins) is hard. Although, if you don't need the old chip, you can remove it in any destructive way you wish that won't harm the actual PCB.
                                        Now the new chip.. that has its own problems. As I said, this particular one has flash memory inside it. So you need a chip that is preprogrammed with the correct firmware for that board (and possibly compatible with that board's current system firmware/BIOS/UEFI version as well), or you need a hardware programmer compatible with those chips (like the SVOD or the RT809F with the optional PEB-1 expansion board) along with a good copy of the firmware itself to use with it.
                                        • piernov
                                          • Jan 2016
                                          • 4439
                                          • France
                                          #40
                                          On some laptops the ITE chip gets programmed automatically when you first apply power if it's blank. So there's a small chance he won't need an external programmer.
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • justice171
                                            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                            by justice171
                                            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                            1. Verified that all critical voltages are present:
                                              • 3.3V and 5V are always present if DC is plugged.
                                              • 1.8V on the BIOS chip is present.
                                            2. Checked the power button functionality:
                                              • When pressed, the voltage drops to 0V, indicating the button is functional.
                                            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                              • Confirmed connectivity is intact, ruling out issues
                                            11-26-2024, 12:39 AM
                                          • claws77
                                            lenovo flex 5 14itl05 power sequence issue
                                            by claws77
                                            hi guys, my motherboard will not start no matter what
                                            when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                            but rest nothing happens no sign of life.
                                            this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                            with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                            but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                            i have no knowledge of motherboards ....
                                            10-20-2024, 02:48 PM
                                          • yaya3gmax
                                            Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                            by yaya3gmax
                                            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                            Symptoms:
                                            • Laptop works normally on a pre-charged battery.
                                            • Battery does not charge when adapter is connected.
                                            • Without battery:
                                              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                              • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                            08-21-2025, 07:16 AM
                                          • SuperJames
                                            Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                            by SuperJames
                                            This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                            Specs
                                            i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                            Backstory
                                            I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                            10-23-2023, 04:09 PM
