LENOVO U330 DA0LZ5MB8B0 Quanta LZ5 REV:D
  • BlueMidnight
    • Jan 2015
    • 489
    Re: LENOVO U330 DA0LZ5MB8B0 Quanta LZ5 REV
    Okay, so that narrows it down a little.
    Working backwards, you can check each of these steps that happen before PLTRST#. All should go high after pressing the power button:
    PCH_THRMTRIP#
    H_CPUPWRGD
    EC_PWROK
    SYS_PWROK
    • kokono
      • Jun 2018
      • 203
      PCH_THRMTRIP#
      H_CPUPWRGD
      EC_PWROK
      SYS_PWROK
      please attention output PL3 ist null Before and after switch on
      i think all these signal also are null
      • BlueMidnight
        • Jan 2015
        • 489
        Okay good, you are getting HWPG signal, so it is entering the S0 power state, and the PCH should be getting all its power rails (assuming no broken traces). But the next step is for the board to read the CPU SVID information and then set the CPU core voltage appropriately. And that isn't happening.
        So it looks like the problem is somewhere in between those 2 steps. Maybe in or around PU3/PQ2.
        Press the power button and check VR_ON / H_VR_ENABLE_MCP on PU3 (pin 8)... it should go high.
        If VR_ON does go high:
        - Check for resistance to ground on +VCCIN. It should have a somewhat low resistance since it's the CPU power rail. But if it is too close to zero, there may be a short.
        - The surrounding components (especially the capacitors and NTC resistor) could be checked.
        Otherwise, the next step would probably be to try replacing PQ2. And then PU3 if necessary.
        If VR_ON does not go high, then the CPU isn't requesting for its core power rail to turn on.. for some reason.
        • kokono
          • Jun 2018
          • 203
          i changed PQ2 and NOW all things ist OK
          • kokono
            • Jun 2018
            • 203
            Very thx for all try and your time
            • BlueMidnight
              • Jan 2015
              • 489
              Awesome! Glad the bad part was found.
              You're welcome.
              • openminded
                • Apr 2017
                • 73
                • home
                #47
                hi, just wanted to say thanks for all the detailed info, that helped me a lot with troubleshooting. I think in my case it might have been an issue with the battery. The CMOS battery was 2.2V and I replaced it but that did not help. Might be a powerboard issue too, it's still something that came back, until I was able to boot without battery. Thank you for sharing all the knowledge !
                  Lenovo E130 Quanta LI2 REVD,E,F Schematic & Board View
                  Lenovo E130 Quanta LI2 REV D,E,F Schematic & Board View...
                  10-02-2024, 02:10 PM
                • davidtgbe
                  LENOVO U330 DA0LZ5MB8D0 Quanta LZ5 REV:D
                  by davidtgbe
                  Hi there,
                  I have this laptop which is not powering on/charging with the AC adapter plugged in.
                  At some point, battery ran out and the laptop did not charge anymore and did not turn on either.
                  First things checked in the MB:
                  - Visual inspection. All clean.
                  - 19V on AC adapter -> OK.
                  - PD11, PF2, PQ20, PQ21 -> OK (fuse, diode, mosfets)
                  - C211 shows a short between GND and MX7 line to U20 (don’t know IT8587 internals, may be it is normal).
                  - PC65 shows a short between GND and 3.3V_ALW2
                  - Consumption 100mA @ 19V
                  10-21-2022, 07:25 AM
                  Lenovo 3000 Series Schematic
                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                  3000 C100 laptop with Braille keyboard
                  Lenovo 3000 C
                  C100, C200 - 15-inch XGA screen
                  Lenovo 3000 N
                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                  N500 - 15.4 inch screen.
                  Lenovo 3000 V
                  V100, V200 - 12.1-inch WXGA models
                  Lenovo 3000 G
                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                  10-04-2024, 06:05 AM
                  Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                  09-06-2024, 06:40 AM
                  This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                  09-06-2024, 06:06 AM
