HP EliteBook 8760w - No CPU VCore
  • Johndill
    • Aug 2015
    • 314
    Hi, I've got a HP EliteBook 8760w with no CPU VCore, L6, L7, L8 all have no Vcore voltage. VCCSA is present. What should I check next? thanks
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: HP EliteBook 8760w - No CPU VCore
    Check enable signal on U1010 pin 7.
    • Johndill
      • Aug 2015
      • 314
      If I counted right, U1010 pin 7 is 0.0mV
      • Francisco.s
        • 686
        • Spain
        Then check PWR_GOOD_3. Pin 4 U1012 should be 3 volts.
        • Johndill
          • Aug 2015
          • 314
          According to the data sheet for pin arrangement, U1012
          pin 1 is 3.3V
          pin 2 is 1.4mV
          pin 3 is 0.0mV
          pin 4 is 0.0mV
          pin 5 is 3.3V
          • Johndill
            • Aug 2015
            • 314
            Bump
            • Johndill
              • Aug 2015
              • 314
              • piernov
                • Jan 2016
                • 4435
                • France
                Apparently PGOOD_MXM is needed for PWR_GOOD_3 to go high and get the CPU power regulator to turn on. PGOOD_MXM comes from the MXM connector apparently, and has a pull-up resistor to +V3S.
                Is there a graphics card plugged in in the MXM connector? If there is, remove it, it may be pulling down the line (for an unknown reason right now).
                • Johndill
                  • Aug 2015
                  • 314
                  Yes the MXM GPU was connected, I'll check again without it
                  • Johndill
                    • Aug 2015
                    • 314
                    With MXM GPU in, L6, L7 and L8 are 0.0mV, cold CPU.
                    With MXM GPU removed, L6, L7 and L8 are open line, hot CPU, PWR_GOOD_3 pin 4 U1012 is 3.3 volts.
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      Is the computer booting without the MXM graphics card? Try to see if there is any HDD activity, any sound coming out from the speakers, if caps lock/num lock trigger the associated LED.
                      This MXM graphics card seems to be pulling down the PWRGD line so try with another graphics card if you have one.
                      • Johndill
                        • Aug 2015
                        • 314
                        If I remember correctly, the caps lock was flashing 5 times with the GPU in.
                        The caps lock stays solid lit without the GPU connected so would it be right to say the motherboard is fine and the issue would be with the GPU?
                        I have a GTX 675M in my Alienware but don't really want to take it out :-)
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Check if you can turn off/on the caps lock light. Put an hard drive with an operating system and check if it's being read. (you should hear the heads moving at least)
                          You'd have to try with another graphics card to make sure it is indeed the issue.
                          • Johndill
                            • Aug 2015
                            • 314
                            Thank you in advance for your help :-)
                            The caps lock was solid lit and did not turn off when pressed.
                            I'll clean it out and reassemble it for easier testing of your suggestions and replay back some time soon when I have completed your tests and maybe bear it and try out the GTX 675M from my Alienware as it's the only working MXM card I have and unfortunately HP didn't enable the intel integrated GPU on this board.
                            • Johndill
                              • Aug 2015
                              • 314
                              Problem solved! I put my Alienware GTX 675M in it and it now boots and displays, is there a way of troubleshooting the MXM card or could I heat it up with a hot air reflow station and see of that will work?
                              • piernov
                                • Jan 2016
                                • 4435
                                • France
                                Great!
                                Could you take pictures of the dead MXM card?
                                • Johndill
                                  • Aug 2015
                                  • 314
                                  Great!
                                  It's a Quadro 3000M
                                  • caspian
                                    • Oct 2015
                                    • 1589
                                    • Laptop
                                    MXM graphics cards has 3 different versions which are probably not compatible. In addition, if you buy a MXM card, it can not be trusted. Thus, finding and buying a compatible MXM card takes time.
                                    to test the old card, first check whether the tantalum capacitors or the coils are shorted or not. but probably, the gpu chip should be failed.
                                      • 20966
                                      Its MXM3.0b . http://forum.notebookreview.com/thre...581056/page-72
                                      • Johndill
                                        • Aug 2015
                                        • 314
                                        Originally posted by SMDFlea
                                        Thanks, it looks like regular GTX cards will work with driver mods
                                          HP EliteBook 8760w 8000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 8760w can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 8760w boardview and 8760w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP EliteBook 8760w is accurate,...
                                          09-06-2024, 05:27 AM
                                          HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:50 AM
