Lenovo b50-45 dc connector help
  • Stevie2001
    • Apr 2018
    • 183
    • irland
    Am trying to connect red and black from dc power supply but the lenovo dc jack has
    Black
    Red
    Blue
    Might have white also
    Should i ignore the blue
    • 21887
    Re: Lenovo b50-45 dc connector help
    Check the schematic and see the . Compal LA-B291P
    • Stevie2001
      • Apr 2018
      • 183
      • irland
      pin-1 red
      pin-5 black
      not sure can you help
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        you can safely ignore any pins other then RED & BLACK. Red is for 19v and black is for ground. Rest of the pins are adp/ps id pins which are not necessary for dc supply. Those pins are important while charging battery.
        • Stevie2001
          • Apr 2018
          • 183
          • irland
          this is what i discovered this is causing the short.
          wonder what part this is a cap or resister.
          and the scratched surface.
          • R_J
            • 9607
            What is blown is similar to (PU401) RF4PG likely PU402 is a RG4QJ
            Could be an SY8208CQNC_QFN10_3X3 but I am not 100% sure
            • Stevie2001
              • Apr 2018
              • 183
              • irland
              2r2 resister??
              • R_J
                • 9607
                The whole ic is missing!
                • Stevie2001
                  • Apr 2018
                  • 183
                  • irland
                  ok this is the bad ic
                  were can i get one of those,ebay will be best if you can help me thanks.
                  with the help of thermal i tracked the bad part fast,life saver
                  • R_J
                    • 9607
                    I do not know, I don't usually repair laptop boards, likely ebay/China. Maybe someone that does laptop repairs can be more help
                    I see that same ic location with what lookslike the same ic but with a different marking code
                    • Stevie2001
                      • Apr 2018
                      • 183
                      • irland
                      i think it maybe this
                      SY8208BQNC_QFN10_3X3
                      http://www.datasheetcafe.com/sy8208b...sheet-silergy/
                        • 21887
                        PU402 is a silergy SY8208CQNC . PU401 is a silergy SY8208BQNC
                        I`ll upload the schematic soon.
                        • R_J
                          • 9607
                          I believe there is a difference between the SY8208CQNC_QFN10_3X3 and the SY8208BQNC_QFN10_3X3
                          See if this helps (page 46)
                          I also saw this:
                          SY8206BQNC / Sy8208bqnc - 3.3V
                          Sy8208cqnc - 5V
                          Sy8208dqnc - 0.95V
                          So you need to replace it with the correct IC
                            • 21887
                            Yes, there is a difference, the SY8208CQNC is a fixed 5V regulator and the SY8208BQNC has a 3V LDO
                              • 21887
                              Lenovo b50-45 schematic
                              • Stevie2001
                                • Apr 2018
                                • 183
                                • irland
                                I changed the ic and now no amps drawing just 0amps 19v.
                                Were can it be
                                • Stevie2001
                                  • Apr 2018
                                  • 183
                                  • irland
                                  This mofset beeps on both sides
                                  bv4y18 4455
                                  drain and source beeping while it's on beep mode
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Test using diode mode, both ways to be sure but it sounds like it could be short.
                                    • Stevie2001
                                      • Apr 2018
                                      • 183
                                      • irland
                                      This was shorted injected amps and detected this ic heating up checked using thermal also,this was replaced with another one that looks same but different value.
                                      I think this is the main problem,it is beeping on most of the pins with gnd.
                                        Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        09-07-2024, 05:00 AM
                                        Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
