Cmos reset works for 7-10 days only
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Hi friends,
    I've faced this problem in
    1. DEll inspiron 3537-LA-9981P
    2. HP 15-R series LA-A992P i3 MB
    3.Lenovo AIO PC C20-30 LA-B691P.
    Problem: Laptop switches but no display. No VS voltage present, Fan doesnt Spins. Doing CMos reset solves the problem and there is display. Cmos put back and packed. Works for 7-10 days and again same issue.
    I've checked each and evry component in RTC Circuit and did'nt find anything wrong in all three cases.
    It is not possible to do cmos reset every week to continue working-So my question is why this is happening.
    In fact i've observed this problem In La-A992 on multiple occasions with different mb each time.
    I seek your valuable suggestions and advice.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Cmos reset works for 7-10 days only
    All three cases have CPU+PCH in one die and are haswell/broadweel platform.
      • 21936
      The first thing i thought of when i read 7-10 days was connected standby
      • tomodachi
        • Apr 2012
        • 612
        • Turkey
        1. DEll inspiron 3537-LA-9981P has ENE KB9012 chip
        2. HP 15-R series LA-A992P i3 MB has ENE KB9012 chip
        3.Lenovo AIO PC C20-30 LA-B691P. I believe also has ENE KB9012 chip
        Always coming across to strange issues with KB9012 series programmable chips. I suggest you to examine datatasheet of this chip.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Yes you are right. All three cases have 9012 as kbc. Can you elaborate a bit more on what to look for in datasheet.
          • tomodachi
            • Apr 2012
            • 612
            • Turkey
            First thing I would do is backup KBC dump first and replace it with a new KBC, then flash the dump to new one.
            Not sure where to start looking in with this issue, but if you able to find a good working KB9012 containing board you can make an ohms and voltages comparison maybe.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Thanks tomodachi for your replies. I do have new kb9012. Will try soldering new kbc and program it. Lets see as it will work for 7-10 days anyways. So update only after 10 days.
              Any other advice from senior members here??
                • 21936
                Were all 3 cases running ULV CPU`s
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Though i'm not 100% sure but i do beleive these newer onboard cpu+pch are all ultra low voltage cpu to extend battery life. In case of lenovo it is quadcore cpu, rest 2 mb dell has i5 cpu and hp has i3 cpu.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    I'm inclined to do what tomodachi has advised on one of these board but my beleif is that it has something to do with PCH rtc section.
                      • 21936
                      Maybe changing the kb9012 will fix the problem as tomodachi said, its a strange problem.
                      The PCH,RTC,Crystlal could have something to do with it.
                      Just for reference,i watched a youtube video for a no pwer inspiron 3537-LA-9981P ,the kb9012 was put in place of a KB930QF A1 ,i don`t know if its pin to pin compatible,its not on any IC compatibility list i have. https://www.youtube.com/watch?v=2CueS2RanQM .
                      • caspian
                        • Oct 2015
                        • 1591
                        • Laptop
                        is the 7-10-day period approximately constant?
                        how many times has this failure happened so far?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          yes, 7-10 days is almost constant . I've faced this issue on Lenovo AIO atlest 5 times in the last 3 months. On HP La-A992p i3 mb, i have similar experience.
                          I'm wondering whether none of you have faced this issue.
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            if it is constant, it seems to be a periodic bios recovery or bios update which is done automatically by KBC or PCH. this is just a guess and I do not know more.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              There is no such phenomenon bro.
                                • 21936
                                Did you check the cmos battery voltage when you took them out. Do you think it has anything to do with the crystal, the hp and dell have the samepart SLG3NB3375V. I looked for a datasheet ,couldn`t find one ,i looked at a different part just for reference
                                http://pdf1.alldatasheet.com/datashe...NT3342VTR.html
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Cmos battery voltage was found ok at 3.06v. Crystal i have already replaced.
                                  • tomodachi
                                    • Apr 2012
                                    • 612
                                    • Turkey
                                    Looking forward to receive your feedback, best of luck friend !
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      I replaced kb9012 as tomodachi suggested and put the old kbc dump into the new one. Delivered to customer on 20.06.2018 and it came back today with the very same symptoms-no display. Did a cmos reset-again display ok.
                                      The only difference this time was a llittle bit more longer span before failing again. It worked for almost 30 days instead of usual 10-12 days.
                                      Finally, i've given up on this as i cant understand what to do.
                                      Thanks all for suggestions.
                                      • piernov
                                        • Jan 2016
                                        • 4439
                                        • France
                                        RTC/CMOS circuit is mostly related to PCH so could be an issue with the PCH itself.
                                        • IamPritesh
                                          TPS 51125 only works after cmos Reset. HP 820 g1
                                          by IamPritesh
                                          Laptop will only start after cmos reset. TPS51125 does not generate 3/5 volt once you shutdown the system and try to turn it on again. Any pointers will be appreciated,
                                          Motherboard - 6050A2560501 - MB - A02
                                          01-23-2025, 03:05 AM
                                        • kotel studios
                                          ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
                                          by kotel studios
                                          Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
                                          Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
                                          I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
                                          12-14-2024, 10:48 AM
                                        • sheffieldyorky
                                          ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                          by sheffieldyorky
                                          Hey there people
                                          While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                          This is what I tried, but not in any order.
                                          Google
                                          YouTube
                                          BIOS
                                          Command Prompt (administrator privileges)
                                          On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                          10-25-2025, 02:22 AM
                                        • GIGA10
                                          Gigabyte G5 KE Clearing CMOS won't reset BIOS Admin password
                                          by GIGA10
                                          Hello everyone. I'm not sure if this post belongs in this section? If not, please kindly move it to right section Mod/Admin.
                                          I have a Gigabyte G5 KE laptop and I have forgotten the BIOS Admin password. I can enter BIOS menu but when trying to enter BIOS settings it ask for my password which I have forgotten. I can boot also in to Windows 11. I have tried to clearing CMOS by removing the CMOS battery for 10h. I have tried also to remove both power battery and CMOS battery and bridge the CMOS 2 pin connector on the motherboard. Then when booting I get a message that NVRAM has been...
                                          12-23-2022, 03:31 AM
                                        • medinfo
                                          840 G4 if shutdown does not start until cmos reset
                                          by medinfo
                                          HP ELitebook 840 G4, if shutdown does not start, until cmos reset or with key WIN+B, when restart it start normaly but if shutdown does not start.
                                          - power button working
                                          - Bios updated to latest
                                          - CMOS Battery changed
                                          - Battery charged
                                          04-13-2023, 11:00 AM
