dell n4050 white plain display
  • sanjayajungthapa
    • Jul 2015
    • 31
    • Nepal
    Dell n4050, white plain display. Laptop is on, Works Everything in external display.
    Changed Screen, LVDS Cable... same problem....
    Help Plzz
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: dell n4050 white plain display
    What do you mean by changed screen?
    • sanjayajungthapa
      • Jul 2015
      • 31
      • Nepal
      i have changed the led screen tooo...but same White display
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Re-check connections. All were secure and correct? Is the T-CON Bd. OK? Is it separate or part of the Screen panel Bd.?
        • mielta
          • Apr 2015
          • 368
          Hi
          messure voltages at the LCD Connector
            • 21874
            Hold down the D key and press power button,it should run a test . If that doesn`t work try this bios,backup your old bios first.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Originally posted by smdflea
              hold down the d key and press power button,it should run a test . If that doesn`t work try this bios,backup your old bios first.
              smdflea, this is not a bios issue.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Measure voltage on Q4902 specially pin6. You should get 15v on pin6. If not there then its likely to be the reason for white display. Try replacing Q4902
                • sanjayajungthapa
                  • Jul 2015
                  • 31
                  • Nepal
                  Thanks Everybody...
                  Solved By Reflowing PCH
                  • yaseenqamar
                    • Aug 2010
                    • 10
                    I need urgent
                    hp probook 650 G3 CLOONEY-6050a2860101-mb-a01
                    BIOS PLZZZZ....
