hp 15r no power problem
    3.3 volt and 5 volt is not available in board after changing step down ic prblem is same
    Re: hp 15r no power problem
    Hi
    Witch board is it?
    Have you schematic?
      have you verify 19V AT THE CHARGING CONNECTEUR AND 19V IN THE FIRST MOSFET AND SECOND MOSFET
        With such a poor description of problem, without mentioning platform,model and specific problem, you can simply forget to get help.
          Originally posted by mielta View Post
          Hi
          Witch board is it?
          Have you schematic?
          c-701p board no
            yes 19v is coming but no any volt in coil
              Check the fet's just after dc jack first. You should get 19v on Pin 1-2-3 & Pin 5-6-7-8 and 23-25v on PIN 4. Check and reply.
