ASUS G74SX short to ground
  • gadgetfix
    • Feb 2018
    • 5
    laptop works but keeps turning off by itself.
    i have found short to ground on nvvdd and +vcore tried injecting voltage to see where is short but still can not find?
    any help is appreciated.
  • gadgetfix
    • Feb 2018
    • 5
    Re: ASUS G74SX short to ground
    also i got no schematics and cant seem to find
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      +vcore shows very low resistance, so problem not likely there since you have said its working. Try flashing bios or clean me region of your bios.
      • adelfr2009
        HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
        by adelfr2009
        I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
        After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
        09-28-2025, 10:21 PM
      • playit
        450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
        by playit
        hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
        09-02-2023, 02:43 AM
      • OOF DIO
        ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
        by OOF DIO
        (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
        (Had 3 problems, now just 1)
        I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
        I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
        I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
        04-19-2025, 05:03 PM
      • jkucukov
        Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
        by jkucukov
        I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
        During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
        02-05-2025, 09:27 PM
      • Leefreeman97
        Diagnosing short to ground issue. pcb from an e scooter
        by Leefreeman97
        Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
        09-19-2025, 03:33 PM
