Question about mofset voltages.
  • Stevie2001
    • Apr 2018
    • 183
    • irland
    The 6 leg or 3 leg mofset if the gate and source produce 19v is that indication being bad.
  • Capacitorial
    Powersupply has all the voltages - Monitor still no power
    by Capacitorial
    Hello guys,
    I have a Philips 240B7QPJEB. The monitor seems completely dead.
    I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
    On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
    The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
    The weird thing is, that the Power LED is powered over the TCON board.
    On The TCON...
    12-28-2024, 02:12 PM
  • pc_okay
    HP BOARD LA-H323P (Not mofset again ?!)
    by pc_okay
    Hello guys,
    I quadruple check my dc mofset and they are not leaking.
    But first one is giving me million and millions ohms in every ways (gate <> source <> drain <> gate) could it be this little b....?
    But I get not voltage after first mofset 0V, I get 0.95V after 2nd mofset.
    On my ic chip i get: (without battery)
    ACN 0.91
    ACP 0.91
    CMNSRC 0.38
    ACDRV 0.05
    ACOK 0
    ACDET 3.1
    IOUT 0
    SDA 0.1
    ILIM 0
    BATDRV 2.2
    SRN 0
    SRP 0
    GND 0
    LODRV 0
    RGN 5....
    10-08-2024, 08:57 AM
  • gjgib
    Help reading schematic voltages input/output
    by gjgib
    Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
    I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
    I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
    I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
    05-06-2024, 08:11 PM
  • RossMoodley1967
    HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
    by RossMoodley1967
    Hello
    Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
    Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
    03-01-2024, 06:07 AM
  • lol999
    Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
    by lol999
    Motherboard after starting show Q code 00.
    No shorts on any rail ( at last I can't finde any)
    All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
    Nothing get hot, PSU starting, all lights came ON....
    One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
    After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
    This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
    01-21-2024, 02:25 PM
