HP Pavilion Notebook - 15-ab127ca (Touch)
  • new
    • Oct 2014
    • 157
    • canada
    anyone here able to help ? i have very strange problem with this laptop . any time you close the lid the laptop lose all the power even the charger light goes off , removing battery won't help , only way if i have to wait like 10 -15 mins then the charger light will come on and you can turn on the laptop and as soon as you turn it on error message appear The system bios has detected your notebook PC was placed in hibernation to avoid overheating .
    The system is now operating normally and your data should remain intact.
    Overheating may occur if the cooling vents are blocked or the operating temperature exceed the specification. The notebook PC should return to normal operation once the situation is resolved.
    System Temperature (90D)" but this issue not related to overheating at all as the laptop runs very cool it just happen anytime you close the lid ... any explanation ? updated the bios no change
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Pavilion Notebook - 15-ab127ca (Touch)
    if you have schematic, then look for "thermal io protection" circuit.
    • new
      • Oct 2014
      • 157
      • canada
      i don't have schematic
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        mb code??
        • new
          • Oct 2014
          • 157
          • canada
          anytime you press on power button or close the lid which both should put the laptop to sleep instead the laptop will lose all the power ,dc charger light goes off and noway to turn it on unless you want for 20 mins or so then it will turn on with error code 90D which this code related to overheating but the system not overheating at all , cpu temp in max load around 45c ... what is the problem ? is this bios bug or motherboard issue ?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            first, lets try to find out if schematic is available for your model and thats why asked for mb code.
            • new
              • Oct 2014
              • 157
              • canada
              Da0x22mb6d0 rev.d
              • subroto
                • Oct 2015
                • 230
                • Bangladesh
                I think it from power option. Power up the Laptop then go to power option. Then check what in the option of "when close the LID".
                Place "Do Nothing" or "Goes to Sleep".
                If no solve then check thermal protection and LID_SW# signal on the circuit.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Schematic is available on premium sites but i dont have account. If anybody can post Quanta X22 schematic, then we can look further.
                  • new
                    • Oct 2014
                    • 157
                    • canada
                    if you close the lid or press power button to put the laptop to sleep or even if you force the laptop to turn offf by long press on power button then the issue will start i even went to bios screen and then i pressed power button and same thing laptop lost power and you can't turn it back unless you wait for like 20 mins then the charger light on the side on dc jack will come on and you will be able to turn it on , so it is not windows related issue nor bios as i reflashed bios 3 times with deference versions , all lead to same result .. so it is not lid switch either could be power button board is the issue but when it dies i still get 3.3V on the power button .... very stange problem
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Hardware issue with either the EC or the thermal sensor and associated circuitry. Could be due to liquid damage.
                      A working TV? How boring!
                      • Artuha
                        • Mar 2018
                        • 25
                        • Latvia
                        This schematic is not applicable to Your board?
                        • dovanh
                          • Dec 2015
                          • 27
                          • Hoàng Văn Thụ
                          boadview
                          • dovanh
                            • Dec 2015
                            • 27
                            • Hoàng Văn Thụ
                            b
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Check page 30 of the schematic for thermal trip and protection.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Thanks for sharing bro
                                • new
                                  • Oct 2014
                                  • 157
                                  • canada
                                  thank you . i'll check and report back
                                  • slashzakk
                                    Daniel
                                    • May 2018
                                    • 13
                                    • Argentina
                                    Hi, can anyone give me the .bin archive ?
                                    have no video on display. thnks
                                    • new
                                      • Oct 2014
                                      • 157
                                      • canada
                                      i got this laptop working but no display
                                        HP Pavilion Pavilion Notebook 15-bc509na 7MW61EA Notebook 15 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Notebook 15-bc509na 7MW61EA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Notebook 15-bc509na 7MW61EA boardview and Pavilion Notebook 15-bc509na 7MW61EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-06-2024, 09:53 AM
                                        HP Pavilion Pavilion Laptop 14-dv0632sa Notebook 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Laptop 14-dv0632sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0632sa boardview and Pavilion Laptop 14-dv0632sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        09-07-2024, 05:50 AM
                                        HP Pavilion Pavilion Laptop 14-dv0569sa Notebook 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Laptop 14-dv0569sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0569sa boardview and Pavilion Laptop 14-dv0569sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        HP Pavilion Pavilion Laptop 15-eh2500sa Notebook 15 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Laptop 15-eh2500sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 15-eh2500sa boardview and Pavilion Laptop 15-eh2500sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        HP Pavilion Pavilion Laptop 14-dv2514sa Notebook 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Laptop 14-dv2514sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2514sa boardview and Pavilion Laptop 14-dv2514sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
