e5-471 no power
  • p7comuter
    • Mar 2015
    • 68
    • Philippines
    Re: e5-471 no power
    Hello guys i have an update,i already trace shorted components.
    +3v rail is now ok,but still wont power
    Rsmrst no response always at 0v...any suggestion pls help
    Sio replacement is my last option but i wanna make sure before i
    Desolder sio chip. How do i know pls any idea?
    How do i know if it8587 chip is bad?
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      Re: e5-471 no power
      RTC_RST# and SRTC_RST# get right voltages?
      • p7comuter
        • Mar 2015
        • 68
        • Philippines
        Re: e5-471 no power
        Tnx,will update tommorow. What else do i check meritosari
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          Re: e5-471 no power
          Found more than 2pcs board with RTC problem on this series, ( Sometimes D17 blown too)
          Also Check RTC_RST# have more 20Kohm resistance to GND. Hope is approx Mohm value.
          if RTC_RST# only 20K, may be hard to fix, till replace SoC.
          Good luck!
          • p7comuter
            • Mar 2015
            • 68
            • Philippines
            Re: e5-471 no power
            update: problem solve!!! thank you guys for support..at the spi bios section i put some jumper at R103,R489,R417,R145,R146..i think i accidentally remove the 2 resistor when i try to remove bios chip thats why my charging light has gone.and think my main problem is shorted caps at +3v rail. thank you guyss
            take note guys this board has no always on voltages at bios chip,,if you found voltage before switch it will not power up and will give 0v rsmrst,try to replace resistor or make a jumper..
            • SACR
              • Jul 2019
              • 30
              • Malaysia
              #26
              Re: e5-471 no power
              Originally posted by JaroTech
              Here are the schematics.
              Thank You for this Schematic 👍
              • valente222
                HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
                by valente222
                I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
                there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
                n, please identify.
                330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
                SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
                I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
                06-27-2024, 06:11 PM
              • air_chair256
                Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
                by air_chair256
                I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
                Tried to reball RAM 1,2,3,4
                Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
                02-13-2024, 06:00 AM
              • javieromex
                Dell G15 5511 LA-K452P won't turn on
                by javieromex
                Hello, any help will be apprecited!
                • Model: Dell G15 5511
                • MB: LA-K452P
                • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                • Customer reported it was turned off and left plugged in during the night and thats it...
                • No signs of liquid damage or burned components.
                Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                I have checked so far:
                04-17-2025, 12:44 PM
              • Prott
                Surface Pro 7 - SLP_S4 present, then gone
                by Prott
                Hello fellow Badcappers,
                I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
                Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what...
                12-03-2023, 06:11 PM
              • lapfix
                Lenovo IdeaPad 3 NM-C961.no display
                by lapfix
                Hello everyone.
                lap and motherboard : IdeaPad 3-15IGL05 Laptop - Type 81WQ
                NM-C961.
                Behaviour : connect charger it power on automatically ,reach 0.170 amp than down to 0.74 amp...no display.
                with battery connected it reach 980 amp than 870 ...no display
                No short ; no corrision no intervention before.
                Try 2 differents bios versions same behaviour.
                Some measuremets :
                PL 1600 = 5valw present
                pl 1100 = 3 vlalw present
                pl 100 = 0.221 v without battery and when battery connected 7.8 volt
                pl 6602 = 1.2 v
                pl 6603 = 1.056v...
                05-29-2025, 05:01 AM
