Asus X555LD, main board don´t power on. Only produces periodic clicks.
  • javi_tecla
    • Feb 2018
    • Spain
    I everyone.
    I'm triying to repair the X555LD main board, but when I plug the power adaptor only produces a periodic sound, like "clicks". When it happens, all the voltage drops to zero and restarts the normal voltages again.
    I checked the adaptor voltaje and it's OK. The voltaje after the first mosfet is ok too.
    I measured the resistance of the coils and the electrolitic capacitors and it's ok.
    I need your help, I don't realice what can happen.
    Regards, and sorry for my English.
  • cacla
    • Apr 2015
    • 444
    Re: Asus X555LD, main board don´t power on. Only produces periodic clicks.
    Chek tne main rails and the 2 mosfets on 19 volts rail
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • semiRocket
      Toshiba 37bv701b power supply main rails
      by semiRocket
      The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
      I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
      Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
      10-26-2025, 01:55 AM
