Dell Inspiron N5110 Fluctuating Voltages
  • JJR
    • Mar 2013
    • 171
    I have here a Dell N5110 that will not power with or without the battery.
    After dismantling I found the CRT board showing 19v when disconnected from the MB but when connected it fluctuates between 1.2v and 3.6v
    When disconnected from the MB PU3801 gives 19v on pins 1,2,3,5,6,7,8 and 3.2v on pin 4
    When connected it gives 1v to 3v on pins 1,2 & 3, 0v to 0.38v on pin 4 and 0v to 1.5v on 6,7,8
    Any help would be appreciated
  • JJR
    • Mar 2013
    • 171
    Re: Dell Inspiron N5110 Fluctuating Voltages
    I also checked PU4002 & PU4003
    PU4002
    1- 0v to 0.38v
    2- 0v to 0.38v
    3- 0v to 0.38v
    4- 0v
    5- 0v to 1.6v
    6- 0v to 1.6v
    7- 0v to 1.6v
    8- 0v to 1.6v
    PU4003
    1- 0v to 0.38v
    2- 0v to 0.38v
    3- 0v to 0.38v
    4- 0v to 1.6v
    5- 0v
    6- 0.38v
    7- 0.38v
    8- 0.38v
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      measure resistance on all pins of PU4002 and PU4003.
      • JJR
        • Mar 2013
        • 171
        Thanks for your reply Caspian, is that resistance from pin to ground?
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          yes, resistance to ground is important on these two transistors.
          • JJR
            • Mar 2013
            • 171
            I wont be able to get back to this until Monday, thanks for you assistance so far.
            • JJR
              • Mar 2013
              • 171
              OK, back to work
              Resistance to ground
              PU4002
              1- 44 ohms
              2- 44 ohms
              3- 44 ohms
              4- 101k ohms
              5- 201k ohms
              6- 201k ohms
              7- 201k ohms
              8- 201k ohms
              PU4003
              1- 43 ohms
              2- 43 ohms
              3- 43 ohms
              4- 201k ohms
              5- 13M ohms
              6- 13M ohms
              7- 13M ohms
              8- 13M ohms
              pins 5-8 steadily drop to 4.5M ohms
              • JJR
                • Mar 2013
                • 171
                PU3801 on CRT Board
                1- 286K ohms
                2- 286k ohms
                3- 286k ohms
                4- 47k ohms
                5- 35M ohms
                6- 35M ohms
                7- 35M ohms
                8- 35M ohms
                • caspian
                  • Oct 2015
                  • 1589
                  • Laptop
                  Now you should check all the components located between PU4002 and PU4003 to discover which one is shorted.
                  • JJR
                    • Mar 2013
                    • 171
                    Thanks Caspian, this takes me a long time as I don't really know what I'm doing and I don't want to fry anything while I am learning.
                    Do those reading indicate a short to you? I am assuming 100K ohms and above is open circuit.
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      A resistance between 100K ohms and 30 Mega Ohms indicates a very good condition in that part of the mainboard. But the resistance of 43 ohms seems too low. Do you know how to inject voltage to find a short?
                      • JJR
                        • Mar 2013
                        • 171
                        I bought a bench psu (30v 5a linear) at the weekend, but a bit scared of frying the board
                        • Techtiger
                          • Oct 2014
                          • 1601
                          • france
                          Caspian you have indicated 43ohms or less seems a short doe’s this apply to every part of the Motherboard ?
                          • mosfett
                            • Feb 2018
                            • 8
                            • MNE
                            Motherboard work in power?
                            • JJR
                              • Mar 2013
                              • 171
                              What concerns me is what to apply voltage to.
                              • caspian
                                • Oct 2015
                                • 1589
                                • Laptop
                                Originally posted by techtiger
                                Caspian you have indicated 43ohms or less seems a short doe's this apply to every part of the Motherboard ?
                                no, it was for this section of the mainboard.
                                • Techtiger
                                  • Oct 2014
                                  • 1601
                                  • france
                                  Ok thanks
                                  • JJR
                                    • Mar 2013
                                    • 171
                                    Unfortunately I had to give up on this board, a used board was found at a very good price so everyone is happy. Except me LOL!
                                    Thanks again for trying Caspian.
                                    Dave
                                    • beetle1303
                                      Wine Chiller - SMPS issue - fluctuating voltages
                                      by beetle1303
                                      My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                      Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                      Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                      Checking further on the primary side: Incoming line input to bridge...
                                      09-04-2023, 10:33 AM
                                      DELL Inspiron 3650 Inspiron i7-6700 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:44 PM
                                      DELL Inspiron 3650 Inspiron i3-6100 Specification for Upgrade or Repair
                                      DELL Inspiron 3250 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3250 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3250 boardview and Inspiron 3250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
