HP G62-b19SL , always lights up .
  • amennone
    • Feb 2015
    • 63
    • italy
    Motherboard :
    pm_a_hpc_s mv_mb_v1
    * P / N: 01013TM00-600-G
    Defect :
    By inserting the power connector without pressing the power button, the power indicator lights up and the fan runs for a few seconds, then stops, after about 20 minutes the fan continues to run at a higher speed. The power indicator always stays on. Keeping the power button pressed, the power indicator turns off and then on again, the display remains black.
    * Even without the power button (physically removed from the motherboard), the defect remains. Absorption 800 milliamps constant.
    We accept suggestions and scheme. Thank you and good job to everybody .
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: HP G62-b19SL , always lights up .
    check if any IC gets hot on the mainboard.
    • helpmepleasethanks
      Thinkpad T440P bios repair after WIFI whitelist mod
      by helpmepleasethanks
      As per the the rules, here are the specifications of my laptop :
      • Make and model number : Thinkpad T440P
      • Serial number (S/N) : PB-03A7V7
      • Model type - Model (MTM) : 20AW-S2N800
      • Bios version : 2.50 (not 100% sure, that's what I remember)
      Here is the problem, and the events leading to it :
      1. Upgrade screen, keyboard, trackpad, RAM and CPU
      2. Reboot and use the laptop for a bit : everything is working fine
      3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
      4. Boot up the device : bios warning, as expected
      5. Shutdown the device again (no power)
      6. Connect the 8-pin clip of a CH341a
      01-09-2025, 12:09 PM
    • pedrolane
      LG 55EA970V OLED / black screen
      by pedrolane
      Hi
      I've found lot of help here with already answered questions, but it seems I'm in a different case.
      My LG 55EA970V OLED screen from 2013 was working well and stopped suddenly while in use, with black screen / no more audio. This model is quite unusual here in europe, so I didn't manage to find someone to help (tv shops etc).
      I've already checked the following :
      • power supply out voltage is fine at 3.5v 12v and 24v pins on the main P202 connector (picture attached)
      • when powered on by remote I can hear the relay "click",
      03-30-2023, 02:56 AM
    • Francesc V.
      Christmas lights - Something I am doing wrong
      by Francesc V.
      Hi:
      i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
      I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
      If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
      Could...
      03-11-2023, 07:38 AM
    • Info13
      Dell H235P-00 Power Supply Failure
      by Info13
      A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
      After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
      ➡️ First test:
      The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
      A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
      I then followed the advice from the forum and replaced...
      10-22-2025, 01:52 PM
    • gabrielA7
      IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
      by gabrielA7
      Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
      I saw that the room LED lights up only when the screen is connected, so quiet.
      We have all the power supplies, even processor, 1.8V
      One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
      I suspect that there may be some leak in the processor.
      Anyway, when I press the power, it...
      10-29-2024, 06:48 AM
