Acer Emachine La-4854P dead
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    I'm not getting any voltage on PIN 5-8 of PQ11. If i jumper from PIN1 to PIN5 of pq11-system boots fine. So rest things are ok.
    So B+ is shorted somewhere but i was unable to find what is wrong.
    PR57/62/65 is ok. MOsfet at PQ10/11 and 12 is ok. I have replaced BQ24751a and checked all resistance near Charging ic.
    Any ideas friends??
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Acer Emachine La-4854P dead
    Voltage on pin 2, 3, 4, 5, 7, 8, 10, 13, 21, 28 of PU5 (BQ24751A) when adapter is connected?
    Resistance to ground of B+ line?
    Resistance across PR57?
    • smali
      • Sep 2014
      • 287
      • Pakistan
      My suggestion is check PQ10 carefully may be something leakage Drain with Gate...or try to replace this P channel mosfet.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        pin2-0.5v
        pin3-0.5v
        pin4-19.0v
        pin5-2.61v
        pin7-0.67v
        pin8-2.56v
        pin10-3.96v
        pin13-0.65v
        pin21-0.5v
        pin28-19.0v
        pr57-46.5ohms
        resistance to b+ line-infinity in diode mode.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Replaced pq10/11/12-still no voltage in pin5-8 of pq11.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            measurements of bq24751a is only with ac adapter connected.
            • smali
              • Sep 2014
              • 287
              • Pakistan
              pin2-0.5v
              pin3-0.5v
              pin4-19.0v
              pin5-2.61v
              pin7-0.67v
              pin8-2.56v
              pin10-3.96v
              pin13-0.65v
              pin21-0.5v
              pin28-19.0v
              pr57-46.5ohms
              According your measurement pin#4 voltage must low ACDRV not working..check pc 45 leakage or shortage.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Yeh pin 4 voltage is wrong ,should be around 12v instead of 19v but I've already checked PC45 and its ok.
                Any further ideads?? This mb is driving me nuts......
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  Check again your fets.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    checked again-not faulty. Still changed them-no result.
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      pin2-0.5v
                      pin3-0.5v
                      pin4-19.0v
                      pin5-2.61v
                      pin7-0.67v
                      pin8-2.56v
                      pin10-3.96v
                      pin13-0.65v
                      pin21-0.5v
                      pin28-19.0v
                      pr57-46.5ohms
                      Resistance across PR57 should be 0.015 ohm, check again. If it's way higher than that it may be bad. Don't forget to take into account the resistance of your multimeter leads and the accuracy of the measurement, the reading may be off by a small amount for such a low resistance.
                      Voltage on pin 10 should be around 3.3V, if it's not you may have a defective charger IC.
                      • bachir2004
                        • Feb 2015
                        • 439
                        • maroc
                        Any ideas friends??
                        let`s keep things simple,first in diode mode measure pq10 , pq11 ,pq12 and reverse black and red probe,
                        should find something like 490V and OL other side.p channel 4407 is easy to find on scratch boards.and let me know.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Those are very basic things. I have already checked those things before posting for help. Anyway, thanks for your ideas Bachir sir
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            I have replaced charger ic twice-the last one from a workig board just to be sure. So charging ic is not bad-100% sure. It should be 3.3v on pin10 but i'm getting a bit higher 3.9v.
                            PR57 is ok-i have measured by taking resistance out of the circuit and even replaced it. No result yet.
                            I have removed lan/cardreader/sound ic.
                            • smali
                              • Sep 2014
                              • 287
                              • Pakistan
                              Check the function of PU1( LM358 )
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                I have checked LM393 as well as LM358A-no problem found, even replaced them. No luck yet.
                                Client has agreed to take back laptop without charging enabled as his battery is almost dead and he dont wants to buy a new one. So I'm about to deliver it to the client today.
                                Would have been happier if could have solved the case as its always a learning lesson.
                                Still thanks for all your time.
                                • techetronic
                                  • May 2017
                                  • 12
                                  • qatar
                                  hello
                                  did you get the solution
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    No , I delivered it to customer with charging disabled as customer agreed as mentioned in post#16
                                    • bripoll
                                      Acer Veriton N4670GT Dead
                                      by bripoll
                                      Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
                                      The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
                                      It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
                                      I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
                                      I have programmed it, but it still won't start, it is dead
                                      Before programming...
                                      11-23-2023, 02:56 PM
                                      09-06-2024, 05:27 AM
                                      Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-07-2024, 05:00 AM
                                      Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 04:10 AM
