Acer4752 Power On Issue
  • dspok
    • Jan 2014
    • 553
    • Nepal
    I have a issue with this Acer 4752 laptop and in many other model I faced similar issue.
    Machine voltages OK, charging OK, 3/5V Ok but won't turn on. If I remove RTC Battery machine turns on itself and display comes out.
    No short or leakage in RTC section, SIO changed, BIOS reprogrammed, Processor changed.
    Is PCH faulty? or something I'm missing please let me know.
    Diagram here.. https://www.badcaps.net/forum/attach...5&d=1392865123
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Acer4752 Power On Issue
    did u get all rsmrst , pwrok and pwrbtn signals ?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      I'm facing same issue with HP15 La-A994p mb. Everything seems to be ok as per schematics. Mb works fine with cmos battery for 10-15 days and then switches and instant off, without any display. Unplug cmos battery again starts working with display. Repeats same issue after 10-15 days. Frustated
      • bachir2004
        • Feb 2015
        • 439
        • maroc
        Originally posted by dspok
        hello,
        i have a issue with this acer 4752 laptop and in many other model i faced similar issue.
        Machine voltages ok, charging ok, 3/5v ok but won't turn on. If i remove rtc battery machine turns on itself and display comes out.
        No short or leakage in rtc section, sio changed, bios reprogrammed, processor changed.
        Is pch faulty? Or something i'm missing please let me know.
        last time i had this problem,i changed the crystal near pch.i do not remmember which model.but i could switch the mobo on by power button with no display but would not turn off untill unplugging charger.
        • dspok
          • Jan 2014
          • 553
          • Nepal
          @ktmmotocross
          Yes all rsmrst , pwrok and pwrbtn are ok. I found Q1901 pin 2 and 3 = 3.3v but no voltage at pin 5 and 6. R1916 and R1909 are ok.
          Laptop still turns on without RTC battery, but doesn't turn off.
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • justice171
            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
            by justice171
            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
            1. Verified that all critical voltages are present:
              • 3.3V and 5V are always present if DC is plugged.
              • 1.8V on the BIOS chip is present.
            2. Checked the power button functionality:
              • When pressed, the voltage drops to 0V, indicating the button is functional.
            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
              • Confirmed connectivity is intact, ruling out issues
            11-26-2024, 12:39 AM
          • claws77
            lenovo flex 5 14itl05 power sequence issue
            by claws77
            hi guys, my motherboard will not start no matter what
            when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
            but rest nothing happens no sign of life.
            this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
            with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
            but now nothing happens no matter how much i wait/ charge/ press and hold power button.
            i have no knowledge of motherboards ....
            10-20-2024, 02:48 PM
          • yaya3gmax
            Laptop Power Issue – Works on Battery, Fails on Adapter Load
            by yaya3gmax
            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
            Symptoms:
            • Laptop works normally on a pre-charged battery.
            • Battery does not charge when adapter is connected.
            • Without battery:
              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
              • Speakers “pop” when power cut occurs indicating harsh sutdown.
              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
            08-21-2025, 07:16 AM
