Re: Lenovo G50-80 Turns on and off within 4-5 seconds
ANSWER
I KNOW I AM TOO LATE TO REPLY
BUT THIS WILL HELP TO ANOTHER PEOPLE WHO HAS SAME ISSUE AND REPEATING SAME MISTAKE
Q25 gate should be active low
"SUSP#" SIGNAL WILL COME AND DEACTIVATE "SUSP" SIGNAL
It mean when ground will come on the gate Q25
Than only "20VSB" will release and activate +5VALW TO +5VS
ANSWER
hi sir what is the value of q25 ? i have the same issue and will try to change q25
Reason: found q25
ok i have checked q25, correct me if i am wrong. when there is power drain side of q25 should have 5V ? i have measured gate pin of q25 give intermitent 5v, i noticed that when the power led turns on the voltage drops and goes back when power led turns off. To switch on q23 pin 4 (gate) should have 5v, so that pin 123(drain) of q23 will have +5vs. i have tested my board and q23 does not have +5vs. my board keeps blinking power led when adapter is plugged in, even if not switched on. also fan seems to spin a bit and stops. i don't really know if q25 is broken i have tested drain and source using diode mode seems to be fine. where does the SUSP# singnal come from ? the diagram has q26 but my board does not have q26.
Reason: corrected my understanding
