Lenovo V560 20069 can't shut down
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have problem with this laptop. After I turn off notebook by Start in Win 7 , lcd goes black, but vent is still on and led also. Any idea how to fix it? Thanks for answer.
  • rakaini
    • Nov 2017
    • pakistan
    Re: Lenovo V560 20069 can't shut down
    please uninstall the VGA & Audio Driver and then check
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      i had same problem and it was bluetooth driver.. it was the problem... i uninstalled the driver and left it witn windows generic and everything worked
      Im Back... sort of...
      • petehall347
        • Jan 2015
        • 4440
        try ,,, shutdown /force
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          Thanks for answers. I tried uninstall drivers,but nothing changed, then I reinstall windows and without drivers notebook lag at Turning off screen. shutdown /force (shutdown -s -f) - also lag.
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            Do you mean the laptop finally has shut down successfully with delay?
            • DeniS182
              • Jun 2014
              • 328
              • Slovakia
              No, the laptop will not turn off. Stuck at
              • petehall347
                • Jan 2015
                • 4440
                how long are you leaving it for ?
                • petehall347
                  • Jan 2015
                  • 4440
                  you could try running a live linux operating system to see if it shuts down ok then .
                  • petehall347
                    • Jan 2015
                    • 4440
                    another thought is look at system logs to see if anything odd is logged there .
                    • qonma
                      Kuli Solder
                      • Jun 2017
                      • 185
                      • INDONESIA
                      Windows system crash, reinstall windows
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Try mild reflow of the whole mb.
                        • DeniS182
                          • Jun 2014
                          • 328
                          • Slovakia
                          I tried linux live cd and also stuck when turning laptop off. And I wait long time.
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            Now you only know the system cannot shut down. you have to find another clue to finally discover the cause of the problem.
                            • petehall347
                              • Jan 2015
                              • 4440
                              all i can think is something in the bios .
                              • petehall347
                                • Jan 2015
                                • 4440
                                maybe look at this ... https://support.microsoft.com/en-gb/...enabled-in-the
                                • DeniS182
                                  • Jun 2014
                                  • 328
                                  • Slovakia
                                  Thanks all for answers, especially to petehall347. After I turn off USB legacy in bios notebook shut down properly.
                                  • caspian
                                    • Oct 2015
                                    • 1591
                                    • Laptop
                                    great job.
                                    This is how experience helps us avoid wrong paths in repair such as IC replacement or chip reflowing.
                                    • petehall347
                                      • Jan 2015
                                      • 4440
                                      nice one ..
                                      p.s i got the clues by using google search .
                                      • coasterghost
                                        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                        by coasterghost
                                        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                        System Hardware:
                                        Processor: AMD Ryzen 7 PRO 5850U
                                        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                        09-08-2025, 10:46 PM
                                      • ktmmotocross
                                        Lenovo B50-70 all power ok but still shut off by 3seconds
                                        by ktmmotocross
                                        Hello
                                        Have this Lenovo B50-70 LA-B091P that strart with all voltages but shut down by about 3 seconds. all voltages is ok, SYS_PWROK is 3.3V, flashed bios but still the same
                                        It have amd gpu, so there can be problem. Any hint? even dis to uma will be good if can be done
                                        Lenovo B50-70 80EW
                                        LA-B091P
                                        sn - MP07V4zp...
                                        03-02-2024, 07:27 AM
                                        Lenovo 3000 Series Schematic
                                        Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                        3000 C100 laptop with Braille keyboard
                                        Lenovo 3000 C
                                        C100, C200 - 15-inch XGA screen
                                        Lenovo 3000 N
                                        N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                        N500 - 15.4 inch screen.
                                        Lenovo 3000 V
                                        V100, V200 - 12.1-inch WXGA models
                                        Lenovo 3000 G
                                        G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                        10-04-2024, 06:05 AM
                                        Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                        09-06-2024, 06:40 AM
                                        This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                        09-06-2024, 06:06 AM
