+3valw to +3vs on acer laptop problem
  • infoplus
    • Aug 2017
    • 83
    • ALGERIA
    Motherboard: COMPAL LA-3581P (ICW50) Rev 1.0
    I have a problem with +3VALW TO +3VS circuit
    SUSP = 5v, VSB = 19V, +3VALW = 3V, 5VS=0V
  • mielta
    • Apr 2015
    • 368
    Re: +3valw to +3vs on acer laptop problem
    Hi
    Remove biosbatterie and then press powerbutton for 60 sec. without ac adapter and Battery.
    means make a hardware reset.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      remove u1 and see if pin 4 of u1 get 19 volt. if yes replace u1.
      • infoplus
        • Aug 2017
        • 83
        • ALGERIA
        I Remove U1 and i get no think This problem is strange....
        • khaahk
          • Dec 2013
          • 810
          • Estonia
          Everything is ok for S5 state.
          After powerbutton pressed KB926 should pull SUSP# high, meaning SUSP is going low and U1 gate will get 19V to open 3VALW to 3VS.
          This mainboard has the famous MCP67 from nvidia. Maybe the ec is not getting answer from MCP and does not give command to change power state.
          • infoplus
            • Aug 2017
            • 83
            • ALGERIA
            I think that i have a short to ground in this lines:
            +3vs, +1.8vs, +1.2vs where is the problem exactly
            • khaahk
              • Dec 2013
              • 810
              • Estonia
              Why do you think that?
              What do you call short to gnd? How many ohms?
              • infoplus
                • Aug 2017
                • 83
                • ALGERIA
                0 ohms and in power supply it show me that there is a short
                • khaahk
                  • Dec 2013
                  • 810
                  • Estonia
                  Then use lab psu to find the short, if needed on all lines.
