IT8527E Datasheet
  • mielta
    • Apr 2015
    • 368
    IT8527E Datasheet
    Hi
    Have everone an Datasheet from IT8527e
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: IT8527E Datasheet
    There is no datasheet available for most SIO chips.
    Laptop technician can only look at schematics to find out SIO's pins.
    • mielta
      • Apr 2015
      • 368
      i have see it on vinafix but i am not registred
      • SoulFreeze
        Help finding datasheet for component marked G34662
        by SoulFreeze
        Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
        Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
        Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
        05-01-2025, 03:56 AM
      • Rainbow_Chameleon
        Searching Datasheet for AM113 IC by O2MICRO
        by Rainbow_Chameleon
        I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
        Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
        If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
        On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
        So if anyone has a datasheet or at least...
        01-23-2025, 12:03 PM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • evgental
        HP prodesk 400/600 G6 mini schematic/datasheet
        by evgental
        Hey everyone,
        I'm looking for a schematic or datasheet for this mini PC. I want to see if I can add another NVMe slot, since my motherboard only has one. If anyone has it, please share. And if you have a motherboard with two NVMe slots, can you send some high-quality pics so I can figure out how to reverse-engineer it and give it a try?
        Thanks a lot!
        08-04-2025, 04:58 PM
      • double_DD
        Component identification and/or datasheet, please
        by double_DD
        Hi all
        I have Synology DS115j that I'm trying to repair.
        I've found a short between G and S on Q13, but it's not on mosfet (when I unsolder it). So I suppose problem might be on mosfet driver - I believe U10 is the driver for 2 surrounding mosfets.
        However, I'm not sure exactly what U10 is, so I cannot find the datasheet. (might be uPI semiconductors, but I cannot find anything on their page)
        Any help is welcome, thanks!...
        07-31-2025, 07:48 AM
