dell inspiron 5458 dead after shut down
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: dell inspiron 5458 dead after shut down
    anyone please help share a schematic for this please
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Originally posted by Romulo
      i dont have schematics for this can someone have this please share. i already tried new cmos battery the problem is laptop turns on but after i shut down cannot turn on again but when i insert low voltage cmos battery i can turn on the laptop and when i shut down i can turn on many times but the problem is laptop beeps 5 short
      5 short beeps is not an issue. U can put the beeps off by cutting the track of "PC BEEPS". Look for it in the sound ic datasheet. For example , to stop this annoying beep on dell cedar 13269_1 mb, just cut the track of pin12 of sound ic. No more beeps.
      But we should try to find why it doesnt turns on when 3v cell inserted.
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        thanks for the response mcplslg123 do you have schematic for this model please if this is the case i need to find out what type of sound ic does this model
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Dont have schematics. Just try to find the datasheet of sound ic.cutting the audio beep or pc beep track works-i have done it on so many dells
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Do you have 3v at switch after inserting 3v cmos battery??
            • Romulo
              • Nov 2016
              • 484
              • Philippines
              #26
              yes i have 3v on switch after inserting 3v cmos battery but when i removed again the cmos battery and start the laptop with charger only plugged in starts automatically and it takes 20 secs to display first fan spinning then stops and then charger light off and then goes on and display comes even i reinsert the 3v cmos battery starts and go to post error date and time not set and when i shut down the laptop cannot turn on again
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                #27
                Here is the schematics document for Dell inspiron 5458.
                first check if it matches your laptop.
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  #28
                  thanks caspian for the schematics i already checked in the rtc1 section voltage on d2501 3D3V_AUX_S5 is there and have 3v but i cant find the C2503?
                  • Romulo
                    • Nov 2016
                    • 484
                    • Philippines
                    #29
                    @mcplslg123 if i cut off the beeping sound could you share how to do it and which pin to disable this board has REALTEK ALC3234
                    • alvin24705
                      • Dec 2015
                      • 16
                      • Indonesia
                      #30
                      this one spesial for u
                      try this one....
                      • Romulo
                        • Nov 2016
                        • 484
                        • Philippines
                        #31
                        thanks but i cannot find on the board the r2502 c2503 voltage on D2501 pin 2 have 3v on 3D3V_AUX_S5 and the on Q2505. i have attached the image of the rtc on the board please help on this
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #32
                          as per the schematics attached by caspian, you need to cut the pin12 track of the sound ic. No need to remove any components. Its labelled "audio pc beeps". Just do it with 100% confidence as i have done this on many many dells and sound from speakers and headphone will work perfectly.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #33
                            check R1720. it should be 330k.Signal name-RTC_AUX_S5
                            • Romulo
                              • Nov 2016
                              • 484
                              • Philippines
                              #34
                              @mcplslg123 thanks for the response ill will check and give feed back
                              • Romulo
                                • Nov 2016
                                • 484
                                • Philippines
                                #35
                                i still cannot find the R1720 on the board maybe ill try to cut the pin12 of realtek ALC3234
                                • alvin24705
                                  • Dec 2015
                                  • 16
                                  • Indonesia
                                  #36
                                  how many ampere on digital power supply?
                                  • Romulo
                                    • Nov 2016
                                    • 484
                                    • Philippines
                                    #37
                                    you mean laptop charger. laptop charger has 3.34amp
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      #38
                                      Go ahead man, atleast you will get rid of those annoying beeps.
                                      • Romulo
                                        • Nov 2016
                                        • 484
                                        • Philippines
                                        #39
                                        @mcplslg123 thanks man i cut pin 12 and now there is no annoying beeps and laptop boots fine with this 1v cmos battery
                                        • caspian
                                          • Oct 2015
                                          • 1589
                                          • Laptop
                                          #40
                                          I am not sure whether the schematics match your laptop or not.
                                          I just found it on the Internet.
                                          check it by comparing it to the mainboard.
                                            DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:36 PM
                                            DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:30 PM
                                            09-12-2024, 03:28 PM
                                            DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                            DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
