Ipad Mini A1489 WiFi not working
  • Rashid36
    • Aug 2014
    • 64
    • Saudi Arabia
    Please Help me out
    greyed out (Software restore new ) same problem even what ever available on youtube i try i need help by hardware (repairing) change antenna too...
    Apple iPad Mini WIFI & 4G Schematic
    Apple iPad Mini WIFI & 4G Schematic...
    10-21-2024, 03:47 AM
  • Michal Timko
    Getac S410 G4 - not working second Wifi NIC.
    by Michal Timko
    Hello, first of all - thank you in advance for help.
    I got an Getac S410 G4 notebook with Intel(R) Wi-Fi 6 AX201 160MHz. Everything works fine, but we need to have another Wifi NIC because of VW/Audi Cars diagnostic software.
    So we added this one Realtek RTL8822CE Wireless LAN 802.11ac PCI-E Network Adapter to a free slot PCI-E 3.0 x1 port.
    NIC is installed correctly, basically it works, but we dont know how to enable the Wifi on it. It seems like it is still in Airplane mode - we are unable to turn of Wifi on this card. BUT - this card will turn on Wifi itself, after some time,...
    01-29-2025, 05:29 PM
  • TrumanHW
    A1708 13 MacBook Pro Fn WiFi stops working | Turn OFF-ON WiFi = Temp Fix (1-6 min)
    by TrumanHW
    WiFi menubar symbol shows hardware stays connected (even when issue occurs)
    WiFi adapter shows normal connectivity symbol & stats: Using Opt+WiFi shows:
    • Tx Rate: 867 Mbps
    • RSSI: -44 dBm
    • Noise: -90 dBm (same as working MBP connected to same router)
    After ~1 min - 7 min, connectivity is lost (no traffic works) until I Disable / Enable WiFi (temporarily fixing again)
    Inspected Antenna connections (look secure) & UP / DL is quick when working (same as good laptop)
    • DL = ~400 Mbps
    • UL = ~17 Mbps...
    09-06-2022, 10:45 AM
  • GeirAndersen
    iPad .pcb file collection
    by GeirAndersen
    I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
    Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
    IPAD COLLECTION 1
    +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
    +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
    +---iPad mini3 820-00008(A1599) 820-00002(A1600)
    +---iPad mini4 820-00180(A1538) 820-00177(A1550)
    +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
    +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
    12-09-2024, 09:28 AM
  • waterchill
    Apple iPad Pro 12,9" 4Gen no charging, but working fine
    by waterchill
    Hey folks, I have this iPad Pro 12,9" 4Gen A2232 here with no charging issue. The main fault was a crossed pins / faulty USB charging port due a bad cable.
    So I started to replace this parts:
    - replaced usb-c port -> no result
    - replaced battery -> no result
    - replaced usb-c chip CD3217B12A -> no result
    - replaced 343S00326 -> no result
    - replaced 343S00327 -> no result
    - replaced 343S00328 -> no result
    I have no more ideas for this issue. There is no short on the whole board, and the iPad is working fine...
    04-30-2024, 05:37 AM
