acer iconia tab a1 830 not charging or power on
  • Doc38343
    • Apr 2015
    • 402
    Hey just tinkering and revisiting some abandoned devices using my new microscope and this tablet - acer iconia tab a1 830 was abandoned here a couple of years ago. We thought the Micro USB charging port was broken but the guy had told me he replaced it. I took the microscope and looked at it and the solder job was horrible it has a pin under the bottom SMD jack that should have been done with hot air. It looked like he had done it with an Iron by just holding it to the jack casing. SO I removed it cleaned and tested the jack off the board and it was fine so i soldered it back. Now I still get nothing past a little device marked KGJB4M but I can find no info on it.
    Would anyone happen to have a schematic or service manual for one of these?
    (I am mostly practicing and trying to learn more on board level issues)
    None of the components have the mask markings to identify their location.
    found a lot of user manuals but nothing else.
    If I knew what that IC was and pin out it would help.
    I will get some better pics using my USB scope in a few got busy for a sec...
  • Doc38343
    • Apr 2015
    • 402
    Re: acer iconia tab a1 830 not charging or power on
    Hey i know this thing isn't worth anything but the idea is to learn by tracing the board fail and if i destroy it there is no great loss... I really need a schematic though. I cannot identify the IC that the 5v stops at and don't know if there is another rail of 1.5 or 3.3 missing that would turn the IC on.
    I figure practice on this as opposed to a $800 board....
    need the experience.
    Thanks!
    • Sojke
      • Apr 2017
      • 131
      • Serbia
      Did you manage to fix it? I have one that wont charge the battery.
      • Wang Tingting
        Acer Nitro 5 AN515-57-536Q not charging
        by Wang Tingting
        I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
        report is also good for battery.
        Following https://www.badcaps.net/forum/troubl...arging-circuit,
        • DCIN/VCC: 19.1
        • ACIN/ACDET: 3v
        • REGN/VDD: 6v
        • CMSRC : 19v
        • ACOK: 3.3v
        • ACDRV: it is 19v, not 25V(when charging, the ACDRV
        09-10-2025, 01:46 PM
      • abrahim110
        [Help Needed] Acer Aspire 5 A517-52G – Removed Onboard RAM, Now Working But Battery Not Charging
        by abrahim110
        🧵 [Help] Acer Aspire 5 A517-52G – Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
        I have an Acer Aspire 5 A517-52G-53NB laptop.
        The onboard (soldered) RAM was faulty, so I physically removed the chip.
        I also successfully modified the BIOS using the SPD Removal Tool – the laptop now boots fine and works with an 8 GB DDR4 SO-DIMM installed.
        ✅ System status:
        • BIOS mod is done (SPD removed)
        • Laptop boots to Windows normally
        • RAM is detected and stable
        ❌ Problem:
        The battery is not charging:
        • Power adapter
        08-06-2025, 06:15 AM
        Acer Iconia B3-A50-K1D2 One 10 Specification for Upgrade or Repair
        This specification for the Acer Iconia B3-A50-K1D2 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the B3-A50-K1D2 boardview and B3-A50-K1D2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Iconia...
        09-06-2024, 07:07 AM
      • titomno2
        Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
        by titomno2
        Hi guys,
        I currently trying to figure out why the laptop of my friend did not charge.
        It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
        At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
        I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
        My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
        06-11-2024, 11:52 AM
      • titomno2
        Acer Nitro AN515-42 Not Charging
        by titomno2
        Hi guys,
        06-11-2024, 02:54 AM
